Gehe zu Seite: |vorherige| Erste . 10 . 20 . 30 . 40 . 49 50 51 52 53 Letzte |nächste|
2024 Samsung OLED TVs | 48" - 83" | S95D/S9AD/S90D/S85D | QD-OLED & WOLED | Anti Glare & G...
ehl
#2634 erstellt: 06. Jul 2025, 12:46
Verwirrung um angeblich fehlendes HGIG mit neuem Tizen 9.0 Upgrade
https://www.flatpane...owfull&id=1751537373
Quelle: reddit
"Tizen 9.0 introduces a redesigned settings menu that can be resized and have its transparency adjusted by the user. It also includes a handful of other interface tweaks, security updates (including CryptoCore), and support for Samsung's Live Translate feature for subtitles. Overall, Tizen 9.0 is a relatively small upgrade.
On the other hand, the update removes the Game HDR option with HGiG
https://www.reddit.c...content=share_button
"I'm sorry but this is factually incorrect. The removal of HGIG mode is a huge issue and it is NOT INTEGRATED into game mode, HDR Static does not enable HGIG mode. They are two different things. The removal of HGIG mode is ONLY affecting 2023 onwards European/UK models at the moment and does not affect the 2025 models. That means
The USA and KOREAN TVs (2023 and onwards) still have the option for HGIG mode in their settings even on the latest Tizen OS.
The 2025 European and TVs also have the HGIG option available as well as the ability to set HDR tone mapping to static/active. This was also possible for us before it was removed in the update. This is a firmware bug.
There is no such thing as integrating HGIG mode, every single TV has the option to manually choose HGIG mode. The PS5 HDR calibration has changed from 15 clicks to 25 clicks because there is no HGIG mode available. This is a firmware bug.
Dazu der Thread inkl. Reaktion auf der offiziellen samsung homepage
https://eu.community...td-p/12731208/page/3
[Beitrag von ehl am 06. Jul 2025, 13:11 bearbeitet]
jogi@tv
#2635 erstellt: 06. Jul 2025, 13:26
was sagen denn die User, die vom glossy Display auf das matte Display umgestiegen sind...wie ist euer Bildeindruck, vorallem in dunkler Umgebung...vermisst ihr die tiefe und den starken Kontrast, wie bei einem glossy Display oder fällt das nicht auf?
Bin echt am überlegen...stehe zwischen LG G5 oder S95D...die C Serie von Samsung wäre nichts für mich.
Vielen Dank im voraus!
trilos
#2636 erstellt: 06. Jul 2025, 15:03
Ich kann den S95D direkt vergleichen mit dem S90D, beide in 65":
Der 65" S95D ist für das Wohnzimmer/Heimkino genau richtig, da wird auch oft tagsüber geguckt, wie z.B. aktuell Tennis aus Wimbledon auf Prime.
Der S90D steht im Schlafzimmer, da wird dann eher abends geguckt, oder, wenn tagsüber, dann verdunkelt.
Der S95D hat m.E. keinen sichtbaren Verlust gegenüber einem glossy OLED, wenn man abends bzw. im Dunkeln schaut.
Dahingegen ist das matte Panel tagsüber ein Gewinn, da sich nicht jede Lichtquelle im Display reflektiert - für mich ist das tagsüber Schauen dadurch viel besser geworden.
Der minimale Verlust, tagsüber, den das matte Display gegenüber einem glossy Display hat, wird meinem Eindruck nach von den massiven Spiegelungen eines glossy-Displays problemlos bei der Gesamtwürdigung konsumiert, sprich "aufgefressen"...
Schönen Sonntag,
Alexander
smett
#2637 erstellt: 06. Jul 2025, 16:22
Stimme Alexander zu 100 Prozent zu.
Hab im Schlafzimmer ein Lg G3 und im lichtdurchfluteten Wohnzimmer ein S95d. Würde es genau so wieder machen. Keine Spiegelungen mehr zu haben ist schon ein Segen. Gucke auch mal tagsüber und habe es gehasst in dunkeln Szenen diese nervigen Spiegelungen zu haben und mich in selbigen angucken zu dürfen/müssen.
Hab den Samsung exklusiv wegen des matten Displays. Wenn ich keine Probleme mit Spiegelungen im Wohnzimmer hätte, würde ich Lg vorziehen.
Javacom3003
#2638 erstellt: 06. Jul 2025, 18:14
Die Diskussion über matt vs. glossy könnte tatsächlich mal beendet werden – wenn sie nicht immer wieder auf veralteten oder halbgaren Annahmen basieren würde. Also hier mal eine differenzierte Klarstellung, warum der Samsung S95D mit mattem QD-OLED-Panel derzeit das TV-Gerät für echte Bild-Enthusiasten ist:
1. Mattes Display – mit Verstand optimiert, nicht „verschlimmbessert“
Samsung hat beim S95D nicht einfach einen Milchglasfilter draufgelegt. Es handelt sich um ein hochwertiges Anti-Reflex-Coating, das gezielt harte Lichtquellen (Fenster, Lampen, Displays) streut, ohne die Bildtiefe drastisch zu beeinträchtigen.
Im direkten Vergleich mit einem klassischen glossy OLED ist die Spiegelarmut in hellen Räumen ein enormer Vorteil.
Der S95D bietet brillantes Schwarz bei Dunkelheit und lesbares, stabiles Bild bei Tageslicht. Das ist kein Kompromiss – das ist aktuell das Beste aus beiden Welten.
2. QD-OLED liefert die spektakuläreren Farben und die höhere Leuchtdichte
Dank Quantum-Dot-Technologie erreicht der S95D satte, voluminöse Farben auch bei hohen Helligkeiten – ohne Weißpixel, wie sie bei WRGB-OLEDs von LG verwendet werden.
Was bedeutet das? Dass Farben bei hellem Content nicht ausbleichen, sondern mit voller Sättigung knallen.
Der Samsung S95D gehört damit zu den farbstärksten Geräten auf dem Markt, mit einem real sichtbaren Unterschied bei HDR-Filmen, Games und sogar SDR-Content.
3. Thema saubere Panels: Die 2024er Charge zeigt extrem geringe Serienstreuung, so gut wie null Color Uniformity und vor allem gleichmäßige Grau- und Hauttöne. Im Gegensatz dazu muss man bei LG weiterhin mit Panel-Lotterie rechnen – selbst beim G4 sind gelbliche Ränder oder vertikale Banding-Probleme keine Seltenheit.
4. Fazit:
Der Samsung S95D war bisher das technologisch fortschrittlichste OLED-Panel am Markt. Wer reflexionsfreies Bild ohne Einbußen bei Kontrast, Schärfe und Farbintensität will, findet im S95D die klar bessere Lösung.
Und nein – das ist kein Kompromiss, sondern gezielte Weiterentwicklung für realistische Wohnsituationen. Nicht jeder wohnt im Referenz-Heimkino mit schwarzem Samt an der Decke – und genau dafür wurde dieses Panel konzipiert.
Wer also glaubt, matt wäre gleichbedeutend mit Bildverlust, hat den S95D wahrscheinlich nie richtig gesehen – oder verwechselt Fortschritt mit Folie.
trilos
#2639 erstellt: 06. Jul 2025, 18:54
Danke für die ausführliche und technisch fundierte Zusammenfassung - und letztlich sagte ich, verkürzt, nichts anderes...
Schönen Abend,
Alexander
jogi@tv
#2640 erstellt: 06. Jul 2025, 19:00
Vielen Dank, für die sehr ausführlichen Antworten!
fakeframe
#2641 erstellt: 07. Jul 2025, 12:33
Schön, dann ist der S95D eben eine Ausnahme, der die Regel bestätigt. Bildvergleiche habe ich ja genug gezeigt.
[Beitrag von fakeframe am 07. Jul 2025, 12:34 bearbeitet]
Javacom3003
#2642 erstellt: 07. Jul 2025, 13:27
fakeframe (Beitrag #2631) schrieb:
Hier noch was zum Vergleich:
Vergleich glossy matt:
https://www.computer...r-large-jpg.1633787/
Wer möchte bitte bei dem Bild noch links auf den Geräten etwas schauen. Das ist so sinnlos wie sonst irgendwas.
Klar geht bei solchen Reflektionen auch beim S95D Kontrast, Farben , Schwarzwert verloren. Aber man sieht wenigstens noch um was es sich handelt.
ehl
#2643 erstellt: 07. Jul 2025, 20:44
s90d in 65" für 1050€ inkl. versand
https://www.euronics...mpaignid=17488431295
nimsa67
#2644 erstellt: 07. Jul 2025, 22:28
Wahnsinnig guter Preis! Leider verkauft Euronics nicht nach AT. Den würde ich sofort kaufen und meinen alten C1 damit ersetzen.
satmark
#2645 erstellt: 08. Jul 2025, 19:49
Am Fluss ist er auch (etwas teurer) im Angebot...
https://amzn.eu/d/eByEBSk
ehl
#2646 erstellt: 08. Jul 2025, 21:17
Das neue Tizen 9 Update entzieht nun nachweislich die HGIG Funktionalität auf den 2024 Modellen und auch hdtvtest hat es auf ihrer Seite aufgegriffen.
"Glücklicherweise" sind die koreanischen Modelle auch betroffen, das macht einen Fix wohl wahrscheinlicher, kann bei samsung aber dauern.
https://www.hdtvtest...ng-tizen-9-0-upgrade
"[On the down side, Tizen 9.0 removes the HGiG Game HDR option, which may come as a blow to those who use their Samsung TV to livestream console games."
https://eu.community...zen-9-0/m-p/12733759
Der "support" hat mal wieder üble Verständnisprobleme und allerlei unsinnige Erklärungen parat
trilos
#2647 erstellt: 19. Jul 2025, 20:37
Beim 65" S95D gibt es in den Bildeinstellungen den Punkt "intelligente Kalibrierung".
Dazu braucht man ein (aktuelles) Smartphone.
Ich selbst nutze im Moment noch ein Samsung S22 als Diensthandy, was wohl kompatibel/nutzbar wäre.
Gibt es hier im Forum Erfahrungen mit dieser Smartphone-basierten S95D Kalibrierung?
Taugt das was? Bringt das gute bzw. seriöse Resultate?
Würde mich über ein paar Rückmeldung von erfahrneren Besitzern freuen.
Schönes Wochenende,
Alexander
ehl
#2648 erstellt: 19. Jul 2025, 21:11
nein, taugt nix und ist bekannt
trilos
#2649 erstellt: 21. Jul 2025, 09:27
OK, danke für die Info.
Ist das Feature nicht wirklich ausgereift, oder ist dieser Ansatz, ein Smartphone zur Kalibrierung zu nutzen, grundsätzlich der falsche Weg?
Ich würde gerne verstehen, warum das (noch) nicht funktioniert....
Jogitronic
#2650 erstellt: 21. Jul 2025, 09:40
Vincent hatte mal am Beispiel des Apple TV 4K gezeigt, was diese Art der Kalibrierung bringt
nimsa67
#2651 erstellt: 21. Jul 2025, 10:16
Ich muss gestehen, ich habe mich damit bisher überhaupt noch nicht beschäftigt. Aber nach diesem Video, welches für mich eher wie ein Werbevideo von Vincent für seine Kalibrierung wirkt, werde ich das womöglich (sobald ich das neue iPhone meiner Mutter einmal zur Hand habe) doch einmal versuchen.
Das klingt für mich jetzt gar nicht sooo schlecht, zumindest im Zusammenspiel mit einem OLED.
D.h. wenn ich einmal viel Zeit habe, werde ich einen ATV an meinen alten C1 hängen (oder mir gleich einen zusätzlich kaufen) und es dort einmal testen.
ehl
#2652 erstellt: 24. Jul 2025, 17:39
Goldeagleno1
#2653 erstellt: 25. Jul 2025, 18:43
@javacom3003
tatsächlich teile ich deine Meinung nicht. Ich finde das Matte-Panel sorgt für ein "totes" Bild.
[Beitrag von Goldeagleno1 am 25. Jul 2025, 18:44 bearbeitet]
Killerweman
#2654 erstellt: 31. Jul 2025, 18:42
Ich habe jetzt ja auch den 77er S90D eig. ausschließlich für Blurays und muss sagen für die 1570 € bei Samsung ist das echt ein toller Gegenwert. Die Software ist im Vgl. zu Panasonic auch gut. Aber gerade im SDR-Bereich ist ein Upgrade bei dunklen Verhältnissen weniger sinnvoll. Da tut sich praktisch seit Jahren nicht mehr allzu viel. Im Prinzip braucht man nur wechseln, wenn man bei UHDs einsteigen will, der TV kaputt ist oder die Helligkeit nachlässt. Ob B2 oder G5 bei SDR im Dunkeln...Wird ähnlich sein. Der Standfuß ist aber echt mies. Ev. liegt es auch an der Größe des TVs, aber so schief ist schon lange kein TV bei mir gestanden. Mit Kartonuntersetzer geht es nun, aber das ist schwach. Mit dem SDR-Bild bei Dunkelheit bin ich noch am Experimentieren. Was haltet ihr von diesen SDR-Nachteinstellungen?
https://www.youtube.com/watch?v=6eBTfDjvR8E
Ich weiß nicht, ev. sollte ich doch nicht das realistischste Bild einstellen. Ist das nicht fast zu warm und zu wenig Helligkeit?
Javacom3003
#2655 erstellt: 02. Aug 2025, 08:36
Goldeagleno1 (Beitrag #2653) schrieb:
@javacom3003
Also ich schaue Filme abends im Dunkeln generell und kann nur sagen, das Bild ist perfekt. Sollte ich tagsüber mal ne Serie gucken oder einfach Nachrichten TV-Programm und habe hier Sonneneinstrahlung verteilt sich das natürlich auf dem Matten Panel aber das interessiert mich überhaupt nicht.
Wenn das deine Wahrnehmung ist, solltest du beim nächsten wieder auf ein spiegelndes gehen aber als Tod empfinde ich hier absolut überhaupt nichts
therevisor
#2656 erstellt: 18. Aug 2025, 13:53
Hallo zusammen, ich besitze seit 6 Wochen den 77S95D und bis jetzt bin ich echt total begeistert. Aber mit dem Start der neuen Fußballsaison bemerke ich Probleme mit Sky UHD. Das Bild ist eindeutig viel zu dunkel. Andere 4K/UHD-Inhalte werden einwandfrei wiedergegeben. Hat jemand ähnliche Probleme und/oder eine Lösung?
[Beitrag von therevisor am 18. Aug 2025, 13:54 bearbeitet]
ehl
#2657 erstellt: 18. Aug 2025, 19:37
So wie hier?
https://www.youtube.com/watch?v=RklSNJgBQaM
Die Wiedergabe des HLG Formats war zmdst. bei den Vorgängern des samsung S95D problematisch, allerdings könnte es auch ein Problem von SKY UHD sein.
Stellt sich die Abdunkelung schleichend ein oder wirkt das Bild von Beginn an zu dunkel?
Man müsste mal zum Vergleich anderes Videomaterial im HLG Format testen, soll z.B. hier zur Verfügung stehen: https://4kmedia.org/tag/hlg/, aber lässt sich leider nicht mehr downloaden.
Dieses Video liegt definitiv in HLG vor, aber wird nur über youtube gestreamt, was ggfls. einen Unterschied in der VErarbeitung durch den TV ausmacht.
https://www.youtube....WXdCotqVVjMEvJWJWMt1
https://www.youtube....VjMEvJWJWMt1&index=2
https://www.youtube.com/watch?v=XZ407bUr9xg
[Beitrag von ehl am 18. Aug 2025, 19:53 bearbeitet]
Javacom3003
#2658 erstellt: 18. Aug 2025, 21:08
Zockt ihr auch auf eurem S95D?
Ich habe mir kürzlich ein Spiel auf der PS5 gegönnt, das mir richtig Spaß macht. Das HUD habe ich dabei so weit wie möglich reduziert – Minimap und Waffen-/Munitionsanzeige sind aus. Nur ein kleines Element oben links bekomme ich nicht deaktiviert.
Spiele im Game-Mode mit folgenden Settings:
– Helligkeit auf 20 reduziert
– Kontrastverstärker und HDR-Verstärker deaktiviert
– Pixel-Shift aktiv
– Logo-Helligkeit anpassen auf „hoch“ (damit statische Elemente gedimmt werden)
Jetzt meine Frage:
Zockt ihr selbst hin und wieder oder regelmäßig auf dem S95D? Habt ihr schon Erfahrungen gemacht, ob das auf Dauer problematisch sein könnte (Stichwort Einbrennen), oder läuft das bei euch entspannt?
Ich denke mal, dass auch Gamer diesen OLE besitzen. Immerhin gibt’s ja eine extra Spielefunktion.
therevisor
#2659 erstellt: 19. Aug 2025, 14:10
Erst einmal danke für die Antwort und die Beispielvideos. Aber diese passen hier nicht. Das Sky-UHD-Bild ist noch dunkler. Es wird auch nicht langsam dunkler, sondern direkt nach Aufruf des Senders.
Mittlerweile habe ich unter "Verbindungen - Gerätesteuerung" das "Erweiterte Eingangssignal" für den von Sky belegten HDMI-Eingang deaktiviert. Dadurch ist zumindest das extreme Abdunkeln der Sky-UHD-Inhalte weggefallen.
Nochmals vielen Dank an ehl. Aber für mich wäre es weiterhin sehr interessant zu wissen, ob andere Besitzer der S95D-Baureihe die gleichen Probleme bei Nutzung von Sky-UHD feststellen.
[Beitrag von therevisor am 19. Aug 2025, 16:19 bearbeitet]
ehl
#2660 erstellt: 19. Aug 2025, 16:34
Handelt es sich um ein HDR oder SDR signal?
Durch Deaktivieren des "erweiterten Eingangssignals" umgehst du die Problematik der fehlerhaften HLG Verarbeitung , indem du damit HDR und damit auch HLG für den Anschluss ausschließt.
HLG überträgt nämlich ein SDR Signal mit HDR bezogenen Zusatzinformationen , welche nur bei HDR bzw. HLG Kompatibiltät ausgewertet werden.
Ansonsten wird nur der SDR Anteil verarbeitet und dargestellt
therevisor
#2661 erstellt: 19. Aug 2025, 17:46
Hm, also ich mit meinem zugegeben eher rudimentären Wissen würde jetzt unterstellen, dass es sich bei Sky-UHD um ein HDR- Signal handelt. Ich kann noch ergänzen, dass es diese Probleme bei meinem vorherigen Panasonic-OLED nicht gab.
ehl
#2662 erstellt: 19. Aug 2025, 19:34
Ja, das HDR Signal hast du für den HDMI Eingang aber deaktiviert, zmdst. in Kombination mit 50fps+, weil die Bandbreite nun begrenzt wird auf einen älteren Standard.
https://www.heimkino...ID=451942#post451942
https://eu.community...s-genau/td-p/7315056
Von deinem Problem wurde auch hier schon berichtet
https://eu.community...sung-tv/td-p/5691002
Ob ein sdr oder HLG HDR Signal anliegt, sollte entweder die Info Taste anzeigen, oder ist in den Einstellungen unter der Angabe von "Gamma" zu sehen.
Steht dort HLG ist es eben HLG
Steht dort hingegen 2.2/2.4/BT.1886 ist es gewöhnliches SDR
Und st.2084 bei HDR10
Vermutlich wird mit erweitertem Eingangssignal dort HLG bei der entsprechend problembehafteten Übertragung angezeigt und mit deaktiviertem erweiterten Eingangssignal eben 2.2/2.4/BT.1886, also SDR.
therevisor
#2663 erstellt: 20. Aug 2025, 13:02
Habe mir die Gammaeinstellungen mit und ohne erweitertem Eingangssignal angesehen und es ist genau so wie du sagst.
Wenn ich das jetzt richtig verstehe, bedeutet es, dass Sky UHD mit HDR ankommt aber vom TV nur deutlich zu dunkel dargestellt werden kann. Jetzt stellt sich natürlich die Frage, ist das ein Fehler von Sky oder vom TV bzw. was kann man dagegen tun?
ehl
#2664 erstellt: 20. Aug 2025, 13:24
Wenn das von mir verlinkte HLG Material den Fehler bei Wiedergabe über den samsung TV nicht aufweist, deutet es eher auf ein Problem von SKY hin.
Ich kann leider nicht selbst mit meinem Panasonic jz oled vergleichen, weil die TVs z.Zt. nicht wieder aufgebaut sind.
Aber ob nun samsung oder sky UHD der eigentliche Grund sein mag, man kann wohl nur das Problem durch deaktivieren von HDR-HLG umgehen.
therevisor
#2665 erstellt: 20. Aug 2025, 14:26
Den Panasonic JZ hatte ich vorher auch, da wurde das Sky UHD-Signal immer einwandfrei dargestellt.
Nochmals vielen Dank für deine Unterstützung.
ehl
#2666 erstellt: 20. Aug 2025, 14:38
Wird denn das verlinkte HLG Material dir subjektiv auch zu dunkel angezeigt oder ohne Auffälligkeiten?
therevisor
#2667 erstellt: 20. Aug 2025, 16:01
Na ja, vielleicht etwas zu dunkel, aber kein Vergleich mit der starken Abdunkelung bei Sky-UHD.
kabaduc
#2668 erstellt: 30. Aug 2025, 19:50
Mir ist aufgefallen das beim Fußballspiel bei schnellen Szenen der Ball verzehrt ist.Was kann ich dagegen machen?
ehl
#2669 erstellt: 30. Aug 2025, 20:41
Samsung's motion processing sucks balls!
Ernsthaft, entweder ein Problem der Bewegtbildverarbeitung an sich, oder es handelte sich bei der Übertragung um interlaced Material und das notwendige Deinterlacing versagte.
Ich würde mal den "Filmmodus" testen
"Es gibt auch noch einen „Filmmodus“. Das ist in den Experteneinstellungen ein Setting, das für TV-Eingangssignale oder 1080i-Inhalt, also Interlaced-Aufnahmen mit Halbbildern, gedacht ist. Hier könnt ihr durchaus mal schauen, ob ihr dadurch eine flüssigere Wiedergabe erreicht. Die Option bleibt ohnehin ausgegraut, wenn keine Interlaced-Inhalte eingehen."
https://stadt-bremer...gen-des-qd-oled-tvs/
Nicht mit dem Filmmaker- oder Movie-mode zu verwechseln!
[Beitrag von ehl am 30. Aug 2025, 20:43 bearbeitet]
Killerweman
#2670 erstellt: 06. Sep 2025, 14:48
Servus, 3 Fragen zum S90D:
- Ich habe mal ein Banding - Video angesehen und muss sagen, dass das ggü. dem alten 65er Pana HZW schon spürbar stärker vorhanden ist. Gerade bei den Grautönen sieht das echt nicht schön aus und es fällt auch im Tizen / Apple - Menü auf. Ich habe aber gelesen, dass sich das u.U. deutlich verbessern kann? Sicher kein Weltuntergang oder Garantiefall, weil es beim gewöhnlichen Konsum nicht auffällt, trotzdem etwas nervig.
- Der Standfuß ist echt mies. Der TV steht damit recht schief (nach vorne / links geneigt). Mit kleinen Untersätzen geht es halbwegs, aber ich hatte noch nie so einen TV, der so dermaßen ungerade stand, obwohl er perfekt auf den Standfuß aufgesetzt wurde. Hattet ihr auch solche Probleme?
- Zur Bildeinstellung bei SDR bei Nacht:
https://www.flatpane...owfull&id=1726124369
- Ich habe jetzt die Settings von Flatpanelshd genommen und die Helligkeit von 19 auf 20 und von Warm 2 auf Warm 1 gestellt. Passt das halbwegs? Spitzenhelligkeit habe ich auf aus, ggf. noch auf Mittel, aber das ist dann wohl etwas zu viel des Guten.
Ansonsten kann man sicher nicht meckern. Gerade für Blurays perfekt.
GroupSettingValue
Power & Energy SavingBrightness OptimisationOff
Picture modeFilmmaker Mode
ExpertBrightness19 (120 nits), higher in bright room
Contrast45
Sharpness0
Color25
Tint (G/R)0
Apply picture settingsAll sources
Picture Clarity SettingsOff
Contrast EnhancerOff
Color ToneWarm2
GammaBT.1886
Shadow Detail0
Color Space SettingsAuto
Color BoosterOff
Peak BrightnessOff (for SDR)
trilos
#2671 erstellt: 06. Sep 2025, 18:31
@ Killerweman
Dein Link führt zum S95D
Sind Deine u.g. Angaben bezogen auf einen S90D?
Schönen Sonntag,
Alexander
[Beitrag von trilos am 06. Sep 2025, 18:32 bearbeitet]
rentemit50
#2672 erstellt: 22. Sep 2025, 07:19
Guten Morgen, ich habe mir vor 4 Wochen den S90 in 83 Zoll geholt, ich weiß, es gibt viele Diskussionen hier ,habe vorher leider nichts gelesen .
Ich bin in Sachen Filme ,Serien und PS5 zocken zufrieden, was gar nicht geht ist Fussball! Ich habe Videos gesehen in Sachen Bildeinstellung,diverse Foren durchforstet , ich bekomme es nicht hin! Nach jeder Wiederholung, nach jedem Kameraschwenk, geht das Bild wieder zum Spiel, ruckelt es 15 Sekunden.
Könnte mal jemand,der einigermaßen zufrieden ist, SEINE Einstellungen mitteilen?🙌
Rhiley88
#2673 erstellt: 23. Sep 2025, 13:02
Ich hatte zwar einen S95F hier, der Stand aber auf dem Fuß auch schief nach links geneigt, obwohl die Bodenplatte des Fußes in der Waage stand.
Ich würde Samsung oder den Händler kontaktieren. Das sollen die in Ordnung bringen oder dir nen Nachlass geben.
ehl
#2674 erstellt: 23. Sep 2025, 13:46
Leider ist die Kadenzerkennung unabhängig der Zwischenbildberechnung dauerhaft aktiv und zudem wird in Sportinhalten auch mal auf 25fps/30fps für Zeitlupen gewechselt, was sie zusätzlich irritieren kann.
Aus welchen Gründen auch immer ist die Bewegtbilderkennung maßgeblich vom Bildkontrast abhängig.
Abhilfe schaffen nur diese Optionen:
Kontrastreicheren Standardmodus nutzen oder Kontrastverstärkung verwenden
Externen Zuspieler verwenden, in den Gamemode wechseln, auf die Zwischenbildberechnung komplett verzichten.
Für möglichst originalgetreue Wiedergabe das "original" preset in der Gsmebar auswählen, was in der Bildabstimmung quasi identisch zum Filmmaker Mode ausfällt.
ehl
#2675 erstellt: 22. Okt 2025, 10:49
Für den S95D ist nun tizen 9 mit funktionierendem HGIG erschienen, Kompatibilität mit dem "game original" mode dürfte weiterhin fehlen, also bleibt die vom samsung support angsprochene Vereinheitlichung von HGIG/ game original aus.
Wir eh wieder in so nervigen Wellen "ausgerollt", also abwarten
https://www.avforums...496149/post-33174486
Maulhofer
#2676 erstellt: 22. Okt 2025, 12:24
Müssen bei einem Update sämtliche Einstellungen neu vorgenommen werden?
MrWhite66
#2677 erstellt: 22. Okt 2025, 13:38
Natürlich nicht!
ehl
#2678 erstellt: 22. Okt 2025, 14:18
Vorausgesetzt samsung verändert die Bildabstimmung nicht mit einem Update
nimsa67
#2679 erstellt: 22. Okt 2025, 17:30
Jogitronic
#2680 erstellt: 22. Okt 2025, 17:35
Was die aber laut den professionellen Kalibrierern gerne mal machen. Damit ist die teuer bezahlte Kalibrierung denn hinfällig ...
rentemit50
#2681 erstellt: 26. Okt 2025, 09:58
@ehl
Ich habe es ganz vergessen:
Vielen Dank für deinen Tipp mit dem externen Zuspieler(im meinem Fall ist es die Sky Q Box)!
Keine Probleme mehr mit dem Bild,du hast mir den TV gerettet!👍🏼🍀
Helge95
#2682 erstellt: 11. Nov 2025, 00:25
Ist der GQ65S93DAT technisch identisch zum GQ65S90DAT bis auf die TV-Fuß Farbe?
Javacom3003
#2683 erstellt: 11. Nov 2025, 15:59
Mal eine Frage, Updates kommen schon lange nicht mehr?!
Sollte da nicht vor Monaten ein Update kommen, wo die Einstellungen überarbeitet wurden?
ehl
#2684 erstellt: 11. Nov 2025, 18:23
Es wurde bereits eines veröffentlicht, aber das wird wieder in so nervigen Wellen ausgerollt.
Einige erhielten es schon vor etlichen Wochen, andere noch heute nicht
Zum Dwnload steht es nicht zur Verfügung, bleibt also nur abwarten
CES 2025: Samsung OLED TVs bis 83"? | S95F S90F S85F | QD-OLED & WOLED | AG & Glossy? 240Hz?
eishölle_2.0 am 12.09.2024  –  Letzte Antwort am 25.11.2024  –  67 Beiträge
Bildeinstellung Samsung S95D GQ65S95DATXZG
Alex2569 am 31.05.2024  –  Letzte Antwort am 14.09.2024  –  5 Beiträge
2022 Samsung OLED TVs in 55", 65" (QD-OLED) S95B Serie | Quantum HDR OLED | LaserSlim Desi...
eishölle_2.0 am 14.12.2021  –  Letzte Antwort am 27.05.2024  –  2414 Beiträge
2023 Samsung OLED TVs | QD-OLED | 55" - 77" | S95C/S90C | 144Hz | OCB
eishölle_2.0 am 10.09.2022  –  Letzte Antwort am 02.12.2024  –  4114 Beiträge
2022 Samsung OLED (LG WRGB)
Ralf65 am 12.12.2021  –  Letzte Antwort am 31.10.2022  –  93 Beiträge
Quantum Dot OLED (QD-OLED) // in 2019 Pilot-Produktion
prouuun am 25.06.2018  –  Letzte Antwort am 15.05.2024  –  685 Beiträge
QD-OLED R&D, Patente, Infos zur Backplanetechnik und Anti-Burn-In, Near-Black etc.
celle am 17.02.2022  –  Letzte Antwort am 19.12.2022  –  10 Beiträge
Samsung OLED
matchiste am 20.09.2018  –  Letzte Antwort am 30.09.2018  –  5 Beiträge
Samsung OLED
kay1212 am 06.10.2019  –  Letzte Antwort am 06.10.2019  –  5 Beiträge
OLED kommt (Samsung 40") !
arise123 am 24.05.2005  –  Letzte Antwort am 27.05.2005  –  2 Beiträge
  • Registrierte Mitglieder931.200 ( Heute: 3 )
  • Neuestes MitgliedalexJob
  • Gesamtzahl an Themen1.564.934
  • Gesamtzahl an Beiträgen21.872.545
