| HIFI-FORUM » Stereo » Elektronik » Verstärker/Receiver » Proton D 1200, ohne Brückungsschalter? | |
Proton D 1200, ohne Brückungsschalter?+A -A |
diskkokind
erstellt: 27. Feb 2017, 14:54
Hallo zusammen, ich habe mir kürzlich zwei Proton D1200 Verstärker für meine "Tannoy Definition 500" gekauft. Nun waren die Amps beim vorherigen Besitzer gebrückt, damit er die doppelte Leistung pro Lautsprecher hatte. Jetzt möchte ich die Boxen aber im normalen Stereo Amp Modus ansteuern da ich den zweiten Proton für meine Onkyo SC 950 verwenden will. Nun habe ich herausgefunden das meine Protons keinen "Bridge Switch" hinten haben. Deshalb hier die Frage wie kann ich die Amps wieder "entbrücken"? Habe hierzu das noch im Netz gefunden, anscheinend bin ich nicht der einzige mit diesem Problem (jedoch umgekehrt): I recently acquired a PROTON D-1200 Power amplifier. Prettiest meters I've ever seen !! Immediately thought how great it would be to use 2 of these stunning beauties as MONO amps... Went to HIFI engine and downloaded the owners manual. I was surprised to see on page 2, a drawing of the rear panel connections shows a bridging switch between the left and right input terminals which turns the amp into a mono amp !!!!! The manual instructs you flip the bridging switch to the "on" position and hook your speaker wire to both red positive terminals.... It also states that by "bridging" the amp more that doubles the power output !!! I excitedly pulled my amp off the shelf and was disappointed to find there was NO BRIDGING switch on my amp. UGH. I went to ebay and checked out Proton D-1200's for sale and none of them had this bridging switch. Interestingly, the two black speaker terminals on the back unscrew completely(and can be removed) and the red terminals unscrew, but are captured and cannot be removed from the amp. Is there a way to run this amp as a MONO amp ?? I would love to get another of these Proton amps and run them as MONO's. Any information would be greatly appreciated !!!!! Dan [Beitrag von diskkokind am 27. Feb 2017, 15:05 bearbeitet] |
Passat
erstellt: 01. Mrz 2017, 16:45
Evtl. befindet sich der Umschalter ja jetzt im Gerät. Also mal Deckel abnehmen und schauen, ob hinten im Bereich der Eingangsbuchsen ein Umschalter vorhanden ist. Grüße Roman |
_ES_
Administrator |
erstellt: 04. Mrz 2017, 02:16
Woher weißt Du das, hat er das gesagt ? Dann müsste er ja auch wissen, wie er das gemacht hat, ohne Schalter.. Gibt tatsächlich 2 Varianten: http://1.bp.blogspot...A/s1600/IMG_3860.JPG http://www.canuckaud...r_amp/images/332651/Ich kann mir nicht vorstellen, das es ein komplettes Layout-Redesign gab, der Schalter wird wohl einfach nicht mehr bestückt worden sein. Sollten die Endstufen tatsächlich gebrückt sein, wird es wohl Drahtbrücken an Stelle des Schalter geben, die entsprechend nachträglich eingebaut wurden. ![]() ![]() Der Ausschnitt des Schaltplans zeigt den Schalter im Stereo-Modus, das untere Bild zeigt die Position, zwischen den Cinchbuchsen. Also Deckel auf, LS-Terminals ausbauen, dann sollte man sehen können, ob es ein Schalter ist, der zwischen den Cinchbuchsen sitzt (wie Passat schon anmerkte, das er nicht mehr von außen zugänglich ist), oder ob dort Drahtbrücken umgesetzt wurden, also in den ursprünglich für den Schalter vorgesehenen Bohrungen in der Platine. Um wieder in den Stereo-Modus zu kommen, müssten sie gem. dem Schaltplan wieder umgesetzt werden. |
Passat
erstellt: 04. Mrz 2017, 02:49
Es gibt sogar 3 Varianten. Die 3. Variante: ![]() Unterschied zur 2. Variante: Plus und Minus der Lautsprecherterminals sind vertauscht. Der Schaltplan kennt nur die 3. Variante. Grüße Roman |
_ES_
Administrator |
erstellt: 04. Mrz 2017, 02:52
Joa, vertauscht...die Polarität ist ja mitgewandert. Ich bin mal gespannt, hoffentlich macht der TE ein Foto von dem, was er sehen wird... |
Endstufe Proton Proton P1200 geschlissen chole am 30.08.2005 – Letzte Antwort am 03.09.2005 – 4 Beiträge |
Kennt jemand Proton Amps? xlupex am 02.11.2005 – Letzte Antwort am 07.01.2019 – 28 Beiträge |
Proton D1200 Problem D1200 am 22.12.2006 – Letzte Antwort am 23.12.2006 – 7 Beiträge |
Klangproblem: Proton D1200 doc_relax am 13.04.2007 – Letzte Antwort am 17.04.2007 – 13 Beiträge |
proton aa- 1150 doc_barni am 18.11.2009 – Letzte Antwort am 26.12.2009 – 8 Beiträge |
Proton AP 1000 doc_barni am 31.12.2009 – Letzte Antwort am 31.12.2009 – 2 Beiträge |
Kleine Probleme mit Proton D1200 neyton am 13.06.2005 – Letzte Antwort am 14.06.2005 – 5 Beiträge |
Proton DPD Schaltung: wie funktionierts? doc_relax am 06.02.2011 – Letzte Antwort am 13.02.2011 – 4 Beiträge |
Class-D Verstärker ohne Digitaleingang lophiomys am 29.10.2010 – Letzte Antwort am 28.12.2010 – 27 Beiträge |
Gebrauchter Proton-Verstärker: Defekt oder i. O.? (Bilder inside!) brigadeleiter am 05.05.2008 – Letzte Antwort am 16.05.2008 – 14 Beiträge |
- Yamaha R-N1000A und R-N800A
- Loudness? ist das gut?
- PRE OUT – MAIN IN, wofür?
- Registrierte Mitglieder931.190 ( Heute: 7 )
- Neuestes MitgliedVegazoneSpel
- Gesamtzahl an Themen1.564.908
- Gesamtzahl an Beiträgen21.871.449
