Gehe zu Seite: |vorherige| Erste 2 3 4 Letzte |nächste|
TCL 2026 - SQD-MiniLED X11L/C8L/C7L/Q7D Pro 75-98", RGB-MinLED RM9L/RM7L 55-115"
celle
#151 erstellt: 06. Mrz 2026, 09:11
celle
#152 erstellt: 06. Mrz 2026, 11:20
celle
#153 erstellt: 10. Mrz 2026, 10:13
98C7LX1 hat sein Energielabel bekommen
https://eprel.ec.eur...onicdisplays/2538275
celle
#154 erstellt: 10. Mrz 2026, 11:18
Rtings hatte wohl Pech bei der Lieferung des X11L:
https://www.avsforum...view=1#post-64504267
Hitzeproblem ist auch Rtings aufgefallen:
We've just started testing it so we really can't say more at this point, but we'll definitely be exploring the heat issue during our testing.
Könnte wohl auch daran liegen:
Some very early findings:
Extremely bright, hitting over 11,000 nits on a 2% window in SDR, but only for a few seconds at a time. It can hold about 4300 nits for a longer time, but throttles down to 790 nits long-term. Highlights will never be on the screen that long with real content anyway, so the end result is that bright specular highlights in real content are incredibly bright.
Build quality: there's an issue with the assembly of our unit, and part of the back panel isn't glued properly. This isn't a review unit, we bought it from a store, so this is concerning. We don't think it'll impact any of our results, it's just disappointing.
We're just getting started on the tests so stay tuned for more! We'll be taking a closer look at thermal controls on the TV, and we'll include FLIR measurements showing how the TV heats over time. Let me know if there's anything else you'd like us to check that's outside of our normal test list!
https://www.avsforum...view=1#post-64504187
Kugelfisch
#155 erstellt: 10. Mrz 2026, 14:44
So, wie ich es verstanden habe, besteht das Hitzeproblem vor allem beim Kalibrieren oder wie hier beim Testen von speziellen Inhalten. Aber ob es auch im normalen TV Konsum auftritt, konnte ich noch nicht lesen, oder gab es dazu schon Infos?
celle
#156 erstellt: 11. Mrz 2026, 09:47
Kommt halt darauf an, wie du den TV benutzt. TCL TVs neigen ja schon eh dazu HDR-Inhalte aufzuhellen, dazu ist er im SDR-Betrieb nicht wirklich begrenzt. Leute die es grell und hell mögen, werden also eher dazu verleitet, den TV auch übertrieben hell im Dauerbetrieb zu nutzen. Wozu kauft man sich sonst auch den hellsten TV im Markt? Die Leute wollen das ja auch nutzen und die Mehrleistung zu anderen TVs benötigt dann ja auch mehr Energie und eine höhere Wärmeabgabe und das ist immer eine schlechterer Weg als bei geringeren Energiebedarf die Leistung zu steigern, wie es bei den OLED-TVs der vorgschriebene Entwicklungsweg ist.
Der TV begrenzt dann in den Tests seine Helligkeit, aber das scheint nicht mehr viel zu nutzen. Die Schutzfunktionen um das Panel nicht zu grillen, sind also nicht effektiv genug implementiert. Eine hohe Wärmebelastung ist schon einmal kein gutes Zeichen für das Paneldesign und die Langlebigkeit.
Das ist halt wieder so ein Punkt, warum man es sich genau überlegen sollte, solch einen TV zu kaufen, gerade in 98" wo Montage und Umtausch ein größerer Aufwand ist. Vertrauen in die Langlebigkeit bekommt man durch solche Feststellungen nicht und bekräftigen eher Vorurteile gegenüber chinesischen Produkten. Das Rtings mit der losen Rückwand nun auch noch einen in der Verarbeitung mangelhaften TV bekommen hat, passt dann auch noch in das vorherrschende Bild. Der kann auf dem Transportweg natürlich einen mit bekommen haben und auch Samsung LCD-TVs waren davon mal betroffen, aber es hinterlässt in Verbindung mit der Überhitzung keinen vertrauenserweckenden Eindruck.
https://www.avsforum...mize=high&width=1920
Ich denke, dass auch TCL in Europa wieder eher den Fokus auf den C7L und C8L setzen wird und der X11L als Imageprodukt nur in geringer Stückzahl verfügbar sein wird. P/L-Verhältnis wird da auch viel besser sein und die Überhitzungsproblematik sollte kein Thema mehr sein. Sony´s Bravia 9 II soll ja auch nur 4000nits bieten. Damit reicht also auch eine abgespecktere TCL-Variante um im Datenblatt mit dem Flaggschiff von Sony mithalten zu können.
Lauter_Heinerbach
#157 erstellt: 11. Mrz 2026, 14:25
Hoffe das ist ihnen eine Lehre die maximalen Nits mit jedem Modell nicht noch weiter zu erhöhen.
Habe noch den X955 von 2023 und im normalen TV-Betrieb die Helligkeit mittlerweile auf 15 von 100 runtergeregelt. Und selbst das ist nicht sonderlich dunkel.
Kugelfisch
#158 erstellt: 11. Mrz 2026, 21:59
Gibt es eigentlich schon brauchbare Infos zur neuen 7er und 8er Serie? Also um wieviel "schlechter" sie sein werden, was Dimmingzonen, max Nits usw. angeht und in welchen Diagonalen sie erhältlich sein werden? Tests habe ich bisher auch noch keine gesehen dazu, so dass TCL bisher scheinbar nur den X11L versendet hat.
Jogitronic
#159 erstellt: 12. Mrz 2026, 15:47
celle
#160 erstellt: 13. Mrz 2026, 12:49
Energielabel des 75X11L:
https://eprel.ec.eur...onicdisplays/2538289
Im Verbauchsdatenblatt schechter eingestuft als der neue LG 77C66 OLED-TV...
celle
#161 erstellt: 16. Mrz 2026, 11:36
Neuer 115RM9L und 98X11L nun für 14999€, statt 8999€?
http://www.hifi-foru...205&postID=1043#1043
celle
#162 erstellt: 16. Mrz 2026, 15:30
ledmen
#163 erstellt: 21. Mrz 2026, 18:07
TCL RM9L: The RGB-Mini 2026 series of LED TVs offers large-size models.
https://hxosplus.gr/vision/tcl-rm9l-rgb-mini-led-tv/
TCL C7L: The entry-level series of Super Quantum Dot panels for 2026
https://hxosplus.gr/vision/tcl-c7l/
SQD Mini LED vs RGB Mini LED: Technical approach based on the new TCL RM9L and TCL X11L
https://hxosplus.gr/vision/sqd-mini-led-vs-rgb-mini-led/
JohnnyPlasmaBoy2000
#164 erstellt: 21. Mrz 2026, 21:03
Schon beeindruckend was bei dem TCL C7L alles dabei ist.
Ist das sozusagen das Value Modell für 99% der User?
MrWhite66
#165 erstellt: 21. Mrz 2026, 21:24
Ja, ähnlich wie beim C7K 2025 ist auch der C7L wieder das Modell mit dem besten P/L Verhältnis und wird sehr sicher wieder viele Käufer finden, die jetzt nicht auf der "Jagd" nach den letzen paar Prozent Bildqualität sind, sonder einfach einen sehr guten TV für einen fairen Preis wollen. Insbesondere die Käufer, die auf eine sehr große Bilddiagonale schielen.
celle
#166 erstellt: 23. Mrz 2026, 10:27
Rtings hat den X11-Test abgeschlossen. Test soll bald veröffentlicht werden - aber natürlich hinter der Bezahlschranke. Das neue SQD-Material führt im Spektralverhalten zu einem höheren Peak im Rot und einem leicht niedrigeren im Grün.
https://www.avsforum...view=1#post-64522498
celle
#167 erstellt: 26. Mrz 2026, 11:21
Rtings-Test zum X11, einiges geblurrt, aber die Textunterschriften und die Vergeliche zu anderen TVs sind lesbar und manche Messwerte auch:
https://www.rtings.com/tv/reviews/tcl/x11l
ledmen
#168 erstellt: 26. Mrz 2026, 21:03
Mini LED on the attack: TCL launches RGB technology and aims to compete with OLED
https://touchit.sk/t...do-novej-ery/857145/
celle
#169 erstellt: 31. Mrz 2026, 09:11
Ein Überblick über die neuen TCL-Modell für die EU. Der MiniRGB-LED-LCD RM7L ist noch unterhalb des C7L angeordnet und besitzt weniger Dimmingzonen. Alle Serie erscheinen zudem auch in 98". Damit hat TCL ganze 7 Serien in 98" im Markt.
TCL X11L: Zollgröße: 75" / 85" / 98" ,Dimmingzon: 11,520 / 14,400 / 20,736
TCL RM9L 85" / 98" / 115" Dimmingzonen: 2,912 / 3,840 / 5,616
TCL C8L (QM8L US) 55" / 65" / 75" / 85" / 98", Dimmingzonen 1,008 / 2,040 / 2,584 / 3,200 / 4,032
TCL C7L (QM7L US) 55" / 65" / 75" / 85" / 98", Dimmingzonen: 800 / 1,152 / 1,352 / 1,624 / 2,176
TCL RM7L 65" / 75" / 85" / 98", Dimmingzonen: 448 / 600 / 720 / 960
A400U 55" / 65" / 75" / 85" / 98", Dimmingzonen 440 / 576 / 836 / 1,008 / 1,344
TCL P8L 55" / 65" / 75" / 85" / 98"*, Dimmingzonen 512* (remaining smaller sizes unknown)
https://www.choose.t...itors-projectors_CGM
celle
#170 erstellt: 31. Mrz 2026, 10:06
Digitalfernsehen hat einen Artikel unter dem Namen "TCL wächst gegen den Trend: Wie der Display-Gigant nach der TV-Krone greift" veröffentlicht:
https://www.digitalf...rone-greift-1176878/
Mittlerweile die Nr. 3 in Europa, in Deutschland aber noch nicht voll angekommen. Gab ja auch lange Zeit keine TCL-TVs im MM und Saturn, die für die öffentliche Wahrnehmung und Markenentwicklung durchaus wichtig sind.
celle
#171 erstellt: 31. Mrz 2026, 10:22
SQD-Serie, und laut Digitalfernsehen gibt es bei der 8er-Serie andere Filter, was merkwürdig wäre, da ja eigentlich das ein Schlüssel für die Farbraumerweiterung von SQD ist:
Der TCL C8L ist in den Größenklassen von 55 bis 98 Zoll erhältlich und bringt die SQD-Technik ins preislich attraktivere Oberklassesegment. Die C8L-Modelle verfügen über bis zu 4032 präzise Local-Dimming-Zonen. Die Spitzenhelligkeit soll bis zu 6000 Nits betragen.
Mit weniger Dimming-Zonen und weiter auseinanderliegender Filter erreichen die C8L-Modelle nicht das Kontrastniveau der X11L-Modelle. Dennoch will TCL auch bei der C8L-Serie ein präziseres Dimming als bei bisherigen QLED-LCDs bieten. HDR-Kontraste und feine leuchtstarke Details sollen sich damit auch mit den C8L-SQD-TVs erstklassig umsetzen lassen.
Die TCL C7L-Modelle in 55 bis 98 Zoll bringen die SQD-Mini-LED-Technik näher an den Massenmarkt. Die Spitzenhelligkeit beträgt bis zu 3000 Nits und es werden bis zu 2176 Local-Dimming-Zonen geboten.
Die wesentlichen SQD-Vorteile wie die Farbvorteile der Super-Quantum-Dot-Technologie bleiben mit den C7L-Modellen erhalten. Im Vergleich zum letztjährigen C7K soll der HDR-Farbumfang des diesjährigen C7L um bis zu 33 Prozent steigen. Zugleich soll die Präzision bei der HDR-Farbdarstellung um bis zu 69 Prozent bei stark gesättigten Farbanteilen zulegen.
Nur 2x HDMI 2.1 beim C7L und wohl auch C8L, dazu beim C7L kein Dolby Atmos Flex:
Im Gegensatz zu den teureren SQD-Modellreihen kommt allerdings kein Hochleistungs-SoC zum Einsatz, es gibt keinen vollwertigen Dolby-Atmos-Flex-Connect-Support, ein Dolby-Vision-2-Max-Update scheint nicht in Planung zu sein und es werden nur zwei vollwertige HDMI-2.1-Schnittstellen geboten.
https://www.digitalf...berstrahlen-1176824/
MiniRGB-LED-Lineup:
Der RM7L wird auch ein anderes Panel als der RM9L besitzen:
Die RM7L-Serie bringt das RGB-Mini-LED-Prinzip in günstigere Preisklassen, muss aber bei Helligkeit, Dimming und Ausstattung klar zurückstecken.
Die grundlegenden Stärken der RGB-Dimming-Zonen inklusive eines riesigen HDR-Farbumfangs bleiben erhalten, doch die Dimming-Zonen-Anzahl fällt drastisch geringer als bei den RM9L-Premium-Modellen aus. Selbst beim LCD-Panel müssen sich die RM7L-Modelle mit HVA-Pro-Qualität begnügen.
Der vollständige Support von HDMI-2.1-Quellen über alle vier HDMI-2.1-Schnittstellen ist vergleichbar zum SQD-TV C8L noch nicht final bestätigt (Chipsatz ist kompatibel, aber geringere Speicherausstattung als RM9L-Modelle).
https://www.digitalf...hiff-heraus-1176858/
RM7L und C8L könnten zudem durch geringeren RAM bei den HDMI 2.1-Anschlüssen kastriert sein. Evtl. werden am Ende doch nur 2 vollwertige HDMI 2.1-Eingänge unterstützt.
[Beitrag von celle am 31. Mrz 2026, 10:45 bearbeitet]
Jogitronic
#172 erstellt: 31. Mrz 2026, 10:43
Sony hat uns doch oft genug gelehrt, dass man anhand von Spezifikationen nicht wirklich auf die Bildqualität schliessen kann. Deswegen hilft so ein Vergleich von Spezifikationen bei einer Kaufentscheidung auch nicht weiter. Man muss einfach mal abwarten, wie die neuen Modelle in der Realität performen. Das z.B. RGB-Mini-LED so einige Tücken hat, gibt TCL ja auch zu.
celle
#173 erstellt: 31. Mrz 2026, 11:05
Die Franzosen kennen schon die Preise und auch hier kostet der 98X11L weiterhin 8999€ und keine 14999€:
Die Kluft im Preisgefüge zwischen C7/8L und dem X11L und RM9L ist aber riesig. Über 4000€ Unterschied zwischen C8L und RM9L ist schon krass.
Dazu der Mini-RGB-LED-LCD wie erwartet zu nah dran am Preis des X11L. Mal gespannt wo dann der 98RM7L liegt. Zwischen 4000-5000€ wäre dann wohl realistisch.
98C8L - 3799€
98C7L - 3299€
98RM9L - 7999€
115RM9L - 12999€
98X11L - 8999€
Sollte das mit den 14999€ für den deutschen Markt stimmen, kein Wunder dass man in Deutschland dann noch nicht so recht Fuß fassen konnte. Laut TCL liegt es ja an komplexen Handelsstrukturen in Deutschland. Da wollen die Händler wohl zuviel Marge, Werbkostenpauschalen und Rabattaktionen?
Weltweit rangiert TCL je nach Display-Marktbereich bereits auf den ersten beiden Plätzen, in Europa ist man unter den Top 3 der wichtigsten TV-Marken.
In Deutschland tut sich TCL schwerer – vor allem wegen komplexer Handelsstrukturen.
[Beitrag von celle am 31. Mrz 2026, 11:06 bearbeitet]
Kugelfisch
#174 erstellt: 31. Mrz 2026, 14:05
Das kann eigentlich nicht sein. Sorry, aber wer kauft in Deutschland den TV für 6.000 Eur mehr als in Frankreich, wo ja auch noch ne höhere MwSt. ist, wenn auch nur 1% mehr (also zumindest noch....) Jetzt in Zeiten von Internet und co mit Preisvergleichen ist das ja zum Scheitern verurteilt.
Ich glaube immer noch, dass der Händler einfach ein paar Dumme gesucht hat, die vor Veröffentlichung schon bestellen und dann nicht mehr auf den Preis schauen, wenn er tatsächlich kommt. Aber mal abwarten, ob ich dann in Frankreich bestellen (muss)...
hristoslav2
#175 erstellt: 01. Apr 2026, 10:33
celle (Beitrag #171) schrieb:
SQD-Serie, und laut Digitalfernsehen gibt es bei der 8er-Serie andere Filter, was merkwürdig wäre, da ja eigentlich das ein Schlüssel für die Farbraumerweiterung von SQD ist:.
https://forum.setcom...%8F.html#post1088026
celle
#176 erstellt: 01. Apr 2026, 10:48
Jogitronic
#177 erstellt: 02. Apr 2026, 20:47
JuergenII
#178 erstellt: 07. Apr 2026, 18:02
celle (Beitrag #176) schrieb:
Weiterer Bericht zum C8L:
Guter Marketing Artikel von TCL.
Wäre er nur halb so gut und mit haltbarer Technik ausgestattet, sicher eine gute Investition. Zumindest die visuellen Tests in den kommenden Wochen dürften zeigen, was wirklich geboten wird.
Was mir allerdings fehlt sind mal technische Videos über die verbauten Komponenten und die Einschätzungen über Haltbarkeit. Das wäre wichtiger als die ganzen visuellen Schwächen, die im normalen Betrieb unter normalen Käufern eh keiner wirklich erkennt. Wobei TCL bei den höherwertigen Modellen ganz ordentliche Komponenten verbauen soll.
breitmaulwiesel
#179 erstellt: 07. Apr 2026, 19:03
Ist das eigentlich normal, dass in TVs 10-bit-Panels verbaut werden? Das ist nämlich ein wenig erwähnter Umstand, und bei PC-Monitoren muss man für natives 10-bit (also ohne Dithering) ziemlich tief in die Tasche greifen. Solche Geräte gelten als Profibedarf.
Jogitronic
#180 erstellt: 07. Apr 2026, 20:49
Wie kommst du darauf, dass TCL das nicht bietet?
Damit wärst du als Laie denn auch überfordert
TCL hat jetzt auch nicht mehr Probleme als die Konkurrenz ...
https://www.rtings.com/tv/learn/longevity-failures
Aber auch das sind letztendlich nur Stichproben.
Wenn du für 5 Jahre Ruhe haben willst, denke mal über eine Garantieverlängerung nach. Danach ist der TV sowieso nicht mehr Wert
JuergenII
#181 erstellt: 08. Apr 2026, 16:40
Schon mal die Foren durchgelesen? Lt. Marketing waren die neuen TV's immer super, die Wahrheit war dann doch mehr durchwachsen.
Ich hätte aber zumindest einen wichtigen Anhaltspunkt für eine Kaufentscheidung
Habe ich auch nicht geschrieben. Bin mit meinem TCL durchaus zufrieden und bleibe der Marke auch treu. Das sie nicht schlecht sind, zeigt ja auch die verlinkte Seite. Aber es wäre halt schon schön zu wissen wie sich das "Innenleben" zwischen den einzelnen Serien unterscheidet.
Wenn du für 5 Jahre Ruhe haben willst, denke mal über eine Garantieverlängerung nach. Danach ist der TV sowieso nicht mehr Wert :Y
Nun, bei diesen "Garantien" sollte man ins Kleingedruckte -sprich AGBs- schauen. Die meisten möglichen Defekte werden dort meist ausgeschlossen oder fallen unter nicht bestimmungsgemäßen Gebrauch, was eigentlich nirgends genau beschrieben ist. Sie beruhigen halt.
Mag sein, dass ein heutiger TV in 5 Jahren keinen Wert mehr hat, aber solange ich ihn nutzen kann und ich mit der Bildqualität zufrieden bin, kann er ruhig deutlich länger funktionieren. Ich erwarte ja nicht, dass sie 25 Jahre halten wie mein LG 32LD450. Der übrigens immer noch funktioniert. Nur die Bildhelligkeit hat deutlich nachgelassen. + 10 Jahre wäre aber ganz gut.
Mein TCL -Erscheinungsjahr 2022 - ist immer noch ein sehr guter TV. Ja er hat ein paar Schwächen, aber eigentlich fallen die nur mir auf.
Wenn ich aber von den normalen Streaminganbietern auf die ganzen 4k super duper Testfilmchen wechsele merke ich sehr deutlich, was das Teil eigentlich kann und wie schlecht die meisten Inhalte sind, die man so täglich konsumiert. Und da ich kein Freund von "dunklen" Filmen bin, fallen sowieso die meisten Bildfehler flach.
Mein Ansatz war eigentlich nur die Werbeversprechen der Hersteller unabhängig der Markte kritisch zu sehen. Langlebigkeit bei den heutigen TV's > 1.000 Euro sichert auf Jahre eine gute Bildqualität. Darauf kommt es eigentlich an. Aber das wird in den Tests kaum in den Vordergrund gerückt.
Kugelfisch
#182 erstellt: 08. Apr 2026, 21:22
In den ersten französischen Shops ist der TCL X11L jetzt gelistet und bestellbar. Lieferdatum wird immer mit Ende April angegeben und die Preise liegen bei den bekannten UVPs, also 8.999 Euro für den 98 Zoll, 6.499 Euro für den 85er und 4.299 Euro für die 75 Zoll Variante.
Dann werden die deutschen Händler sicher in Kürze nachziehen und die Preise mehr oder weniger identisch sein....
Jogitronic
#183 erstellt: 18. Apr 2026, 16:58
TCL SQD vs. RGB -- 2026 QM8L, QM7L, and RM8L
Jogitronic
#184 erstellt: 19. Apr 2026, 19:05
85 Zoll QM8L Review
Jogitronic
#185 erstellt: 20. Apr 2026, 23:43
X11L Review von RTINGS
[Beitrag von Jogitronic am 20. Apr 2026, 23:44 bearbeitet]
sicariox
#186 erstellt: 22. Apr 2026, 08:44
Ich kenne den Youtuber nicht und der Test ist auch nicht sonderlich ausführlich, aber angenehm unaufgeregt.
Es ist auch kein Schönwetter Bericht wie es sonst gerne so ist.
[Beitrag von sicariox am 22. Apr 2026, 08:45 bearbeitet]
Frankfurter_
#187 erstellt: 26. Apr 2026, 17:57
Hallo hat jemand schon den C7l? Wollte eigentlich den C7k kaufen der sehr gut sein soll deshalb weiß ich nicht ob 400 euro mehr was bringen für das neue modell. Schaue nur streaming und ab und zu playstation 5 am spielen
MrWhite66
#188 erstellt: 26. Apr 2026, 18:10
Wenn du grundsätzlich bereit bist, ca. 400€ mehr in die Hand zu nehmen, dann wäre es sinnvoller, du greifst statt einem C7L zu einem C8K. Denn das ist dann schon nochmal eine deutliche Steigerung, statt der leichten Weiterentwicklung von C7K auf C7L.
[Beitrag von MrWhite66 am 26. Apr 2026, 18:18 bearbeitet]
Frankfurter_
#189 erstellt: 26. Apr 2026, 18:18
leider gibt es es den c8k nur ab 65 zoll .brauche 55 zoll
MrWhite66
#190 erstellt: 26. Apr 2026, 18:32
Bei einem 55 Zoll ist der aktuelle Preisunterschied von C7K auf C7L auf keinem Fall gerechtfertigt. Für 400€ bekommst ja schon locker einen OLED TV und/oder 65 Zoll TV. Das wären dann viel eher echte Alternativen, als dass man jetzt 400€ mehr für einen 55 Zoll C7L auf den Tisch legt. Also entweder 55C7K oder ein 55 Zoll OLED TV bzw. gab es die Tage einen 65 Zoll B5 auch für effektiv ca. 750€.
Frankfurter_
#191 erstellt: 26. Apr 2026, 21:27
vielen dank .wie gesagt 55 zoll reicht mir . hab grade ein gutes video gesehn auf youtube von
TecTracks HD ersteindruck und paar messungen vom TLC 7l. nur minimale unterschiede zumjetzigen zeitpunkt gegenüber dem c7k
[Beitrag von Frankfurter_ am 26. Apr 2026, 21:29 bearbeitet]
Kugelfisch
#192 erstellt: 01. Mai 2026, 07:32
Moin zusammen,
hat jemand irgendwelche neuen Infos zum Erscheinungsdatum für den X11L gesehen? Wir sind ja mittlerweile im Mai angekommen und bisher habe ich nichts finden können. Im April sollte es doch eigentlich losgehen, aber bisher nichts. Ich finde immer nur einen einzigen Shop in Deutschland, der die Geräte völlig überteuert anbietet, aber auch nichts an Lager hat. Hat jemand Infos, wann die Geräte in Deutschland zu kaufen sind?
Jogitronic
#193 erstellt: 01. Mai 2026, 08:16
Die verweisen zum Kauf ja auf die Expert Läden. Gehe doch einfach zum Expert hin und frage dort nach
Eventer
#194 erstellt: 04. Mai 2026, 14:42
SQD-Mini-LED-Fernseher: TCL bringt X11L, C8L und C7L zum „Einführungspreis“
"Anlass für die Bekanntgabe der Preise ist die Markteinführung des unter dem X11L angesiedelten C8L, den TCL ebenfalls von 98 Zoll bis minimal 65 Zoll zur Auswahl stellt. Die im März noch für April in Aussicht gestellte Serie kommt somit (vorerst?) ohne die kleinste 55-Zoll-Option nach Deutschland. Der Einführungspreis liegt bis zu 3.000 Euro unterhalb der unverbindlichen Preisempfehlung."
https://www.computer...uehrungspreis.97171/
Mitte Mai...
Kugelfisch
#195 erstellt: 04. Mai 2026, 20:13
Oh Mann, was ist denn das schon wieder für ein Chaos.... Die wollen in Deutschland ernsthaft für den 98X11L dann 14.999 als UVP haben und in Italien und Frankreich kann man den 98X11L schon für die ursprünglichen 8.999 kaufen und bestellen mit Lieferung Mitte Mai.
Bin gespannt, für welchen Preis man ihn dann tatsächlich bei MM, Saturn und Amazon bestellen kann.
MrWhite66
#196 erstellt: 05. Mai 2026, 06:14
Warte doch mal ab, bis die Geräte auch wirklich flächendeckend in DE bzw. Europa verfügbar sind. Die Straßenpreise sind bei TCL und Hisense Modellen doch durch die Bank weg meist sehr gut. Die UVP spielt doch bei TVs eine sehr geringe Rolle. Klar, solche TVs wie der X11L sind keine Volumenmodelle, und kosten schon ihren Preis, aber von der UVP ist der Straßenpreis dann doch weit weg.
Jogitronic
#197 erstellt: 06. Mai 2026, 11:20
Jogitronic
#198 erstellt: 07. Mai 2026, 07:34
Really The Best? - TCL X11L Review (3 Months Later)
Jogitronic
#199 erstellt: 09. Mai 2026, 21:56
Jogitronic
#200 erstellt: 11. Mai 2026, 16:36
131% Rec.2020?! TCL’s RGBC (Cyan) Display Explained… & More
LeDeNi
#201 erstellt: 11. Mai 2026, 22:44
Es führt kein Weg mehr an TCL vorbei
TCL 2021 MiniLED 4K 65", 75" / 8K 65", 75", 85"
Ralf65 am 04.01.2021  –  Letzte Antwort am 31.07.2022  –  84 Beiträge
TCL 4K MiniLED 2019 65X10
Ralf65 am 15.01.2020  –  Letzte Antwort am 13.05.2021  –  98 Beiträge
TCL (98)X955 Erfahrungen
rampi* am 15.05.2024  –  Letzte Antwort am 03.12.2024  –  62 Beiträge
TCL 8K 75" X915
Ralf65 am 08.05.2020  –  Letzte Antwort am 11.05.2020  –  7 Beiträge
TCL 2020 Serie 6 (R635) Mini-LED TV 55"/65"/75"
Ralf65 am 11.08.2020  –  Letzte Antwort am 19.12.2020  –  12 Beiträge
TCL Line-Up 2025
Ralf65 am 05.09.2024  –  Letzte Antwort am 02.12.2024  –  16 Beiträge
TCL U40S7606DS, TCL U49S7606DS, TCL U55S7606DS
bernd_b am 13.10.2014  –  Letzte Antwort am 13.10.2015  –  16 Beiträge
TCL U55S6806S
MrFurkii am 27.12.2019  –  Letzte Antwort am 27.12.2019  –  4 Beiträge
TCL T8A vs. T8B
MartyMcFly96 am 14.05.2024  –  Letzte Antwort am 25.05.2024  –  2 Beiträge
Erfahrungen mit TCL, insb. 75EP660 ?
finy07 am 20.01.2020  –  Letzte Antwort am 03.04.2020  –  6 Beiträge
  • Registrierte Mitglieder931.199 ( Heute: 2 )
  • Neuestes MitgliedHiFiFan75
  • Gesamtzahl an Themen1.564.935
  • Gesamtzahl an Beiträgen21.872.636
Top Hersteller in TCL Widget schließen
