| HIFI-FORUM » English » Stereo (Engl.) » INFO ON PROAC STUDIO 130 & 140. | |
INFO ON PROAC STUDIO 130 & 140.+A -A |
Prithvi
erstellt: 03. Mrz 2005, 21:04
Hi! Guys, Some info on the new ProAc Studio 130 & 140 models for you ProAc fans out there. The Studio 130 replaces the award winning Studio 125 and has taken two years to bring to market. This period was spent re-designing the slimmer and stiffer cabinet, changing the port routing from the rear to the base of the cabinet/plinth and investigating and testing many different combinations of drive unit construction and crossover component improvements. The Cabinet This has been redesigned with slimmer and shallower proportions to aid dispersion and is also more rigid. The floor porting now loads the reworked bass driver which features a new chassis and motor assembly, this design combination giving a faster, cleaner bass. The new 1" dome tweeter which replaces the previous 3/4" dome is similar to those used in their higher-end models and the two units are seamlessly mated via a new crossover network which is split for optional bi-amping and bi-wiring. Every aspect of the Studio 125 has been improved upon with the new Studio 130 and the sound is now nimbler, faster and more open with greater efficiency and detail whilst retaining the trademark ProAc natural sound. The reduced cabinet proportions make it easier to blend in with both traditional and modern décor with a range of four veneer options. Specifications Studio 130 Dimensions Height on plinth with coned feet 965mm Depth 240mm Width 190mm Bass Driver New 165mm ProAc unit with coated cone, raised spider assembly for greater linearity and large shielded magnet assembly Tweeter ProAc 25mm coated silk dome with special coating and inner damping Crossover HQ network using the finest components with option for bi-amping/bi-wiring and utilising oxygen free cable Finishes Black Ash-Mahogany-Cherry-Maple Mode Floor standing with spikes Recommended Amplifiers 15-150 watts Frequency Response 25 Hz - 30 KHz Sensitivity Nominal Impedance 88.5 db linear for 1 watt at 1 metre 8 Ohms Weight 16 Kgs each with spikes and plinths Grille Acoustically transparent crimplene The ProAc Studio 140 Developed from the Studio 130, the 140 has slightly larger cabinet dimensions, an additional bass driver and a reworked crossover network. The sensitivity is high at 91db with a nominal impedance of 4 Ohms. These enhancements produce a significant increase in weight, scale, soundstage and bass power handling making this model an ideal choice for both two channel and home theatre systems where more volume and or sensitivity are required. All these benefits are housed in a package which admirably demonstrates the high build quality that has become synonymous with the ProAc brand. Specifications Studio 140 Dimensions Height on plinth with coned feet 1040mm Depth 280mm Width 190mm Bass Driver (Two) New 165mm ProAc unit with coated cone, raised spider assembly for greater linearity and large shielded magnet assembly Tweeter ProAc 25mm coated silk dome with special coating and inner damping Crossover HQ network using the finest components with option for bi-amping/bi-wiring and utilising oxygen free cable Finishes Black Ash-Mahogany-Cherry-Maple Mode Floor standing with spikes Recommended Amplifiers 15-250 watts Frequency Response 25 Hz - 30 KHz Sensitivity Nominal Impedance 91db linear for 1watt at 1 metre 4 Ohms Weight 20 kgs each with spikes and plinths Grille Acoustically transparent crimplene Rgds Prithvi ![]() ![]() ![]()
[Beitrag von Prithvi am 03. Mrz 2005, 21:12 bearbeitet] |
Arj
erstellt: 04. Mrz 2005, 11:35
Hi Prithvi are these priced above the 125 or in the same range ? rgds |
Prithvi
erstellt: 04. Mrz 2005, 19:53
way above man |
NO MORE DEMOS OF PROAC STUDIO 125 Prithvi am 02.03.2005 – Letzte Antwort am 02.03.2005 – 3 Beiträge |
Tough Comparison Linn Ninka vs ProAC Studio 130 vpriyan am 20.12.2006 – Letzte Antwort am 21.12.2006 – 9 Beiträge |
PROAC D15s finally on demo at ABSOLUTE PHASE. Prithvi am 25.02.2005 – Letzte Antwort am 01.03.2005 – 15 Beiträge |
ProAc D100 Prithvi am 28.01.2005 – Letzte Antwort am 30.01.2005 – 3 Beiträge |
Proac tweeters thebrightonian am 24.05.2005 – Letzte Antwort am 26.05.2005 – 7 Beiträge |
Urgent...any info on Klipsch RF3 abhi.pani am 21.03.2005 – Letzte Antwort am 21.03.2005 – 6 Beiträge |
Help on Info needed : Stereo amplifier fuse Ronnie22 am 17.09.2006 – Letzte Antwort am 18.09.2006 – 11 Beiträge |
Request Adive & Info On Upsampling DVD Players Amp_Nut am 26.06.2007 – Letzte Antwort am 21.07.2007 – 22 Beiträge |
Really sad too day. Prithvi am 03.03.2005 – Letzte Antwort am 04.03.2005 – 3 Beiträge |
ProAc Responce D2 with Leben Prithvi am 08.04.2008 – Letzte Antwort am 08.04.2008 – 4 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder931.096 ( Heute: 1 )
- Neuestes Mitgliedfabsi0011
- Gesamtzahl an Themen1.564.722
- Gesamtzahl an Beiträgen21.863.748
