| HIFI-FORUM » Surround & Heimkino » Lautsprecher » Klipsch Reference IV technische Daten | |
Klipsch Reference IV technische Daten+A -A |
Sp1rit
erstellt: 03. Feb 2006, 14:53
Hallo, die Technischen Daten der Reference IV Serie sind seid ein paar Tagen auf der Hompage von Klipsch. Mich wundert, dass der neue Center RC 64 eine sehr hoch untere Gerenzfrequenz gegenüber dem RC 62 und dem RC 7 hat. Wisst ihr vielleicht warum das so ist? Hier nochmal die Daten: RC 64 FREQUENCY RESPONSE: 62Hz-21kHz +/-3dB POWER HANDLING: 200W RMS / 800W Peak SENSITIVITY: 99dB @ 2.83V / 1m NOMINAL IMPEDANCE: 8 ohms compatible HIGH FREQUENCY DRIVERS: 1.25" (3.2cm) Titanium diaphragm compression driver mated to 90x60 square Tractrix® Horn HIGH FREQ CROSSOVER: 1150Hz, 1800Hz LOW FREQUENCY DRIVERS: Quad 6.5" (16.5cm) High-output Cerametallic™ cone woofers ENCLOSURE TYPE: Sealed HEIGHT: 8" (20.3cm) WIDTH: 33" (83.8cm) DEPTH: 13.5" (34.3cm) MOUNTING: Uptilt and Downtilt feet WEIGHT: 61 lbs (27.7kg) FINISHES: Cherry or Black Ash wood veneer BUILT FROM: 2006 RC 62 FREQUENCY RESPONSE: 57Hz-23kHz +/-3dB POWER HANDLING: 150W RMS / 600W Peak SENSITIVITY: 98dB @ 2.83V / 1m NOMINAL IMPEDANCE: 8 ohms compatible HIGH FREQUENCY DRIVERS: 1" (2.54cm) Titanium diaphragm compression driver mated to 90x60 square Tractrix® Horn HIGH FREQ CROSSOVER: 1150Hz, 1650Hz LOW FREQUENCY DRIVERS: Dual 6.5" (16.5cm) Cerametallic™ cone woofers ENCLOSURE TYPE: Bass-reflex via dual front-firing ports HEIGHT: 8" (20.3cm) WIDTH: 23.5" (59.7cm) DEPTH: 12.5" (31.8cm) MOUNTING: Uptilt and Downtilt feet WEIGHT: 32lbs (14.5kg) FINISHES: Cherry or Black Ash woodgrain vinyl BUILT FROM: 2006 RC 7 FREQUENCY RESPONSE: 45Hz-20kHz ±3dB POWER HANDLING: 200 w max continuous (800 w peak) SENSITIVITY: 98dB @ 2.83 volts/1 meter NOMINAL IMPEDANCE: 8 ohms CROSSOVER FREQUENCY: HF: 1950Hz MF: 550Hz TWEETER: K-67-KV 1.75" (4.45cm) Titanium dome compression driver HIGH FREQUENCY HORN: 8" square 90°x60° Tractrix® Horn WOOFER: Two K-1083-SB 8" (20.32cm) Cerametallic® cone / cast polymer frame ENCLOSURE MATERIAL: MDF ENCLOSURE TYPE: Bass reflex via dual rear-firing ports INPUT CONNECTIONS: 2 sets of binding post speaker terminals DIMENSIONS: 9" (23cm) x 26" (66.5cm) x 12" (30.7cm) MOUNTING: Dual Downtilt feet WEIGHT: 42 lbs. (19kg) FINISHES: Cherry or Black wood veneer BUILT FROM: 2001 BUILT UNTIL: 2006 Gruß Sp1rit [Beitrag von Sp1rit am 03. Feb 2006, 17:34 bearbeitet] |
bulla
erstellt: 04. Feb 2006, 16:44
Hoher Wirkungsgrad, geschlossenes Gehäuse, kleiner Tieftöner... da kommt eins zum anderen.. Klipsch ist glaub ich ohnehin ein Verfechter der 80hz-Trennungs-Theorie, ähnlich Teufel. Da der Center unterhalb 80hz dann eh nix mehr zu tun hat, braucht er auch nicht auf Tiefgang getrimmt zu werden... |
Dirkxxx
erstellt: 05. Jul 2010, 21:22
kann jemand was dazu sagen, worin die sich klanglich unterscheiden? interessant wäre, wenn jemand beide center kennt und beurteilen kann. wenn möglich im selben hörraum mit den selben komponenten. |
Klipsch Reference IV und MKII kombinieren Franky-LH am 20.01.2013 – Letzte Antwort am 28.01.2013 – 20 Beiträge |
Klipsch Reference und Reference Premiere mischbar? Nemesis200SX am 02.04.2017 – Letzte Antwort am 08.01.2019 – 6 Beiträge |
Infinity Beta vs Klipsch Reference Powerheart am 08.03.2011 – Letzte Antwort am 12.03.2011 – 8 Beiträge |
informationen zu infinity reference 31i enom am 20.05.2003 – Letzte Antwort am 03.06.2005 – 3 Beiträge |
Technische Daten Bose companion 3 Stoki1 am 21.09.2007 – Letzte Antwort am 22.09.2007 – 3 Beiträge |
Klipsch REFERENCE PREMIERE HD WIRELESS Erfahrungen __jackersoul__ am 15.05.2016 – Letzte Antwort am 11.01.2018 – 2 Beiträge |
Vergleich Klipsch Reference vs. XTZ Cinema Niiggii am 11.09.2016 – Letzte Antwort am 15.02.2020 – 29 Beiträge |
Neuling Klipsch Reference Premiere Serie perfekt einstellen Diamond_72 am 21.10.2019 – Letzte Antwort am 10.11.2019 – 2 Beiträge |
Klipsch Reference R-51M / Focal Chorus 706 *soundOFmusic* am 28.01.2020 – Letzte Antwort am 06.02.2020 – 2 Beiträge |
rp oder reference serie Indiziert_Zero am 28.11.2023 – Letzte Antwort am 25.12.2023 – 3 Beiträge |
- Plus/Minus vertauschen?
- Stammtisch " Heco Celan "
- Registrierte Mitglieder931.075 ( Heute: 1 )
- Neuestes Mitgliedemiliopridgen
- Gesamtzahl an Themen1.564.674
- Gesamtzahl an Beiträgen21.862.441
