| HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Onkyo A 8450 Vollverstärker | |
Onkyo A 8450 Vollverstärker+A -A |
CarlM.
#101
erstellt: 06. Jul 2025, 20:54
Look into #11, where Johannes postet his optimized schematics: http://www.hifi-foru...-marked_1245973.htmlIt is not 100% identical but very close to it. It offers a good orientation. Remember: in most cases the difference of potentials between emitter and basis must be about 0,6V ... NPN B>E PNP B<E [Beitrag von CarlM. am 06. Jul 2025, 20:56 bearbeitet] |
gemaux
#102
erstellt: 06. Jul 2025, 21:27
Thanks for your help. I'll check all that again but I suspect D 509 D511 which light up little Best regards |
gemaux
#103
erstellt: 08. Jul 2025, 14:39
Hello Between B and E (B - and E+) I find : Q515 : -0,644V Q511 : +0,786V Q512 : 0,704V Q513 : +0,665V Q601 : -0,516V Q603 : +0,569V D505 lights up a little and lights down after a second D505 : +1,35V D506 : +0,637V D507 : +0,2V D509 : +0,54V D510 : +0,577V D511 : +1,78V D512 : +1,73V I suspect D505 D511 and D512 (?) What do you think ? Should I change them? LTZ R15 are difficult to find . Which ones may I change them with? Regards [Beitrag von gemaux am 08. Jul 2025, 14:46 bearbeitet] |
CarlM.
#104
erstellt: 08. Jul 2025, 21:54
Here you find the datasheet: https://datasheet4u.com/pdf-down/L/T/Z/LTZ-R15_Rohm.pdfAll the LTZ-R15 should produce a difference between 1,70 to 2,30V. Max. forward voltage of 1SS133 is about 1,2V (see datasheet for values depending on current) . https://mm.digikey.c...s/docus/9/1ss133.pdfSuspect: D507 p.s. if you are not sure: desolder and test outside the circuit. [Beitrag von CarlM. am 08. Jul 2025, 22:20 bearbeitet] |
gemaux
#105
erstellt: 14. Jul 2025, 12:52
Hello I have 1,47V between anode D505 and cathode D507 (0,76V between D 506/D508) and 2,3V between anode D509 and cathode D511 (2,28V between D510/D512) R527 : 46,8 kohms. The values seams to be good when I measure separately from the board D505,D507 and Q511,Q513,Q515 will be replaced I already changed Q517. And I hope it will be the solution ..... Regards |
CarlM.
#106
erstellt: 14. Jul 2025, 22:39
Don't forget: There's a feedback line from the output to the first stage (differential amp). Therefore a fault will cause anormal values all over the complete circuit. If the actual focussed stage is okay I would seach the faulty part in the first stages. In some cases I unsolder all of the transistors to check them unconnected. Then it is possible as well to proof theother parts on the pcb. Good luck! [Beitrag von CarlM. am 14. Jul 2025, 22:40 bearbeitet] |
gemaux
#107
erstellt: 16. Jul 2025, 16:37
OK I checked separately Q503 Q505 Q507 Q509 .They are good. When I remove only one of them the lamps light on . The lamp lights off and the relay switches only when I remove Q515 alone..... I have a doubt : On what reference point are the voltages indicated on the diagram measured? ground? Ex :-48,8V on B of Q515 I find strange measures. Maybe a short circuit as well Thank you again.. Regards |
CarlM.
#108
erstellt: 16. Jul 2025, 19:46
Yes. I always fix the black cable (= COM) of the multimeter to the metal of the chassis. Then I can focus on the red cable (= 0..200 VDC). The lamp lights on in two cases: - shortcut - the bias is not limited (faulty bias circuit) [Beitrag von CarlM. am 16. Jul 2025, 19:49 bearbeitet] |
gemaux
#109
erstellt: 19. Jul 2025, 10:30
Hello I finally found a short circuit ..... C of Q517 was not isolated from the heatsink.....I had replaced the original one with a equivalent and did not notice this difference .... Bad mistake Everithing works fine now . Many thanks for your help and patience |
CarlM.
#110
erstellt: 19. Jul 2025, 17:34
No problem ... I'm glad that I could support you. Good luck! Carl |
Defekter Onkyo A-8450 MannOhnePlan am 04.03.2005 – Letzte Antwort am 04.02.2014 – 11 Beiträge |
Onkyo A-8450 Kanalausfall rechts denkfisch am 19.05.2014 – Letzte Antwort am 23.05.2014 – 5 Beiträge |
Onkyo Integra A-8450 - linker Kanal verzerrt Holak am 21.11.2009 – Letzte Antwort am 24.11.2009 – 5 Beiträge |
Suche für Onkyo A 8450 Schaltplan Körting_Freak am 10.01.2012 – Letzte Antwort am 03.05.2024 – 5 Beiträge |
Weniger Bass auf einem Kanal - Onkyo A-8450, was tun? Juulsn am 10.01.2013 – Letzte Antwort am 24.02.2021 – 11 Beiträge |
Onkyo A-8450 Soundprobleme auf einem Kanal, bei niedriger Lautstärke MrHooky am 26.08.2017 – Letzte Antwort am 11.09.2017 – 23 Beiträge |
Onkyo A 8830 defekt der_bader am 07.12.2011 – Letzte Antwort am 11.12.2011 – 3 Beiträge |
Onkyo Integra A-8780 laebaworscht am 17.05.2011 – Letzte Antwort am 03.09.2011 – 3 Beiträge |
Verstärker Onkyo A-8051 kana20 am 17.05.2009 – Letzte Antwort am 21.05.2009 – 2 Beiträge |
Onkyo A-9555 Problem BFR4 am 07.04.2010 – Letzte Antwort am 05.11.2011 – 3 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder931.146 ( Heute: 4 )
- Neuestes MitgliedNeck70
- Gesamtzahl an Themen1.564.819
- Gesamtzahl an Beiträgen21.868.233
