Gehe zu Seite: |vorherige| Erste .. 60 . 70 . 80 . 90 . 95 96 97 98 99 100 101 102 103 104 . 110 . Letzte |nächste|
LG OLED 2025 - B5 α8/evo C5 α9/evo G5, M5, W5 mit 4-Stack-OLED α11/ 42-97"
deimos83
#4920 erstellt: 16. Jan 2026, 17:01
Jogitronic (Beitrag #4917) schrieb:
DV mit den internen Apps war bislang dunkler als bei externer Zuspielung. Ob das jetzt immer noch zutrifft, habe ich mal für den Filmmaker Bildmodus überprüft ....
dank dir für deine Tests hier immer
Tigerdragon
#4921 erstellt: 17. Jan 2026, 21:35
Gibt mittlerweile einen Trick um DV Heller zu bekommen ohne "Lebhaft" zu benutzen.
Just following up for anyone interested: There was some discussion of this on the AVForums site, so I think I have a better idea of what to do. I was putting way too much information in there, and while it doesn't look like I did any damage, it's better to go with the least amount of information as possible. So for Google and search purposes, here are my directions on what I did:
Create a file titled "DolbyVision_UserDisplayConfiguration.txt"
In the file, only include the modes you want to edit. The following are the default values according to this
site for each:
[PictureMode = 0]
DBrightness = 0.7
[PictureMode = 1]
DBrightness = 0.3
[PictureMode = 2]
DBrightness = 0.0
[PictureMode = 3]
DBrightness = 0.3
[PictureMode = 4]
DBrightness = 0.3
The picture mode numbers correspond like this:
0=Vivid
1= Cinema Home
2= FMM
3 = Standard
4 = Game
A common place to start is making FMM [PictureMode = 2] or Cinema Home [PictureMode = 1] set to 0.5, but you can experiment. I settled on 0.4 for FMM in my room, but some might like 6 or 7. You can edit any mode, only one at a time or all at once.
Place your edited “DolbyVision_UserDisplayConfiguration.txt" file on a USB drive.
Plug the USB drive into your G5 and turn it on.
There will be a prompt to ask if you want to explore the drive. Say no.
Turn on some content with Dolby Vision.
You will see a prompt to ask if you want to update the new configuration. Agree to update.
You’re done! You should see a much brighter picture on any mode you edited.
Don’t forget to eject the USB drive.
Some disclaimers and notes:
Do this at your own risk.
I’m not a calibrator, and I don’t know what I’m doing. I just wanted DV to be as bright as HDR with tone mapping on but I thought Vivid looked off or too bright. I wanted a DV Bright mode.
You can make changes and follow the steps again to update it as many times as you'd like.
I think that is it. Some things I don’t know still:
Do these settings persist after firmware updates?
Do they persist after a factory reset?
Why doesn’t LG just add a “Dolby Vision Luminance” setting in the menu that corresponds to this so we don’t have to monkey around with this dumb process? They don’t even need Dolby Vision 2 or auto light sensors, just add this as a menu option. Dolby Vision brightness fixed forever. Done.
Please chime in if you have any corrections to this! If you’re willing to take the risk, I think it really fixes any Dolby Vision criticism for this TV and makes it more like a Sony or TCL mini-led with DV Bright modes, except better because it’s OLED. I was honestly contemplating selling the G5 and going back to a 2026 TCL or a Samsung but now with this, I’m good for many years I think.
Quelle: https://www.avsforum.com/posts/64408899/
Hat bei mir funktioniert! Mit 0.6 und FMM sieht das ganze nun endlich Hell genug aus So kann ich tatsächlich DV genießen.
Jogitronic
#4922 erstellt: 18. Jan 2026, 00:18
Man kann "Lebhaft" ja auch ganz einfach dunkler machen ...
ehl
#4923 erstellt: 18. Jan 2026, 00:38
"lebhaft" übersättigt aber auch zusätzlich zur Helligkeitssteigerung
dank dir für deine Tests hier immer :)
Deine Aussage bezog sich aber eigtl. auf den cinema home DV mode, nicht FMM
deimos83 (Beitrag #4916) schrieb:
hat jemand den Eindruck dass Cinema Home DV auf dem G5 mit der neuen FW heller ist?
schreiben einige auf avsforums
Jogitronic
#4924 erstellt: 18. Jan 2026, 00:58
Genau genommen hätte man die Helligkeit vor und nach dem Update messen müssen.
Bei Bedarf könnte ich auch diese Werte messen - obwohl LG ja offensichtlich nichts an den Bildparametern geändert hat.
Bei externer Zuspielung ist der DV FMM jedenfalls so hell, dass man an sich nicht auf andere Bildmodi ausweichen muss. Da ich andere Modi nicht mehr verwende, fand ich den FMM viel spannender
[Beitrag von Jogitronic am 18. Jan 2026, 01:07 bearbeitet]
Leon7791
#4925 erstellt: 18. Jan 2026, 02:29
Leider nein. Lebhaft mag zwar eine höhere Grundhelligkeit haben aber erreicht nur 1800nit max. einzig und allein der FMM erreicht die 2500nit spitzenhelligkeit
Jogitronic
#4926 erstellt: 18. Jan 2026, 10:23
Das ist denn einer der Kompromisse die man beim Aufhellen eingehen muss. Dem Panel geht da wohl "die Puste aus". In der Regel verschwinden durch das zusätzliche Aufhellen Bildinformationen in den hellsten Bildinhalten ("Ausbrennen"), da der TV diesen Bereich nicht passend / weiter aufhellen kann. Das fällt halt kaum auf.
anelmarie
#4927 erstellt: 18. Jan 2026, 12:01
Verstehe ich hier etwas falsch , oder keine Ahnung. Wieso wollt ihr so extrem hell gucken, macht ihr das wirklich? Macht für mich keinen Sinn.
*chiefsteve*
#4928 erstellt: 18. Jan 2026, 12:17
DV ist generell ein dunkler abgestimmter mode...kommt dann noch ein reltaiv dunkel abgestimmter content(gutes beispiel netflix: sandman) dazu saufen diverse bildinfos einfach ab,verschwinden einfach z.b. sterne im weltraum(gutes beispiel : life,cooles alienmovie)...schaltest du dann zwischen helleren und dunkleren presets hin und her wird SEHR schnell deutlich wo der SINN von helleren presets liegt
[Beitrag von *chiefsteve* am 18. Jan 2026, 12:18 bearbeitet]
Jogitronic
#4929 erstellt: 18. Jan 2026, 13:05
DV und HDR10 sind Bildmodi, welche für die Wiedergabe in einem Raum mit Restlicht vorgesehen sind. Wenn man dann in der entsprechenden Umgebung glotzt, säuft da auch nichts im dunklem Bereich ab.
Das "Absaufen" wird auch nicht durch den TV verursacht, sondern durch unsere eingeschränkte Wahrnehmung.
Jogitronic
#4930 erstellt: 18. Jan 2026, 13:09
Wie kann man nur solche Filme in heller Umgebung anschauen ...
*chiefsteve*
#4931 erstellt: 18. Jan 2026, 13:17
wie commst du drauf..???...da war nie die rede von.selbstvertsändlich schau ich movies in gediegen abgedunkelter beleuchtung...allerdings nicht im schwarzen loch,muss auch nicht sein um DV und HDR zu geniessen...und au contraire..."absaufen" kann sehr wohl durch dunkle modi begünstigt und auch erzeugt werden...anyway ...immer das geblubber...der lg bietet möglichkeiten sehr nahe am ab vergleich presets und deren bildinfo zu TESTEN....für JEDERMANN ohne fachwissen und messkompetenz.....wer das nicht NUTZT und selbst vergleicht,was sache ist,dem hilft auch geballte lesekompetenz nicht weiter
[Beitrag von *chiefsteve* am 18. Jan 2026, 13:24 bearbeitet]
Jogitronic
#4932 erstellt: 18. Jan 2026, 13:36
Ich stelle lediglich klar, das deine Aussage nicht zutrifft - jedenfalls nicht, wenn der G5 korrekt eingestellt ist ...
*chiefsteve*
#4933 erstellt: 18. Jan 2026, 13:44
wenn du bei sandman und life im abgedunkeltem raum zwischen FMM und LEBHAFT hin und her schaltest.....SIEHST (auch du ) ,wie bild informationen verschwinden,bzw. wieder auftauchen....ISSO
Tigerdragon
#4934 erstellt: 18. Jan 2026, 14:02
Das Problem bei Lebhaft sind sie grellen überstrahlten Farben, ich mag es zwar bunt aber lebhaft überzieht die Farben absolut gruselig.
Ich schau btw. nur im komplett dunklen Raum und DV ist viel zu dunkel im FFM selbst mit "Cinema" preset ist es mir viel zu dunkel. Gerade, wenn der content dunkler gemastered ist kommt es einem vor als hätte man eine Sonnenbrille auf
Tigerdragon
#4935 erstellt: 18. Jan 2026, 14:03
Ich hatte lebhaft schon bei "40" ändert aber nichts an den viel zu grellen Farben.
*chiefsteve*
#4936 erstellt: 18. Jan 2026, 14:06
...wenn du bei farbe auf 47 gehst und auf warm 30...passt es eigentlich recht gut
deimos83
#4937 erstellt: 18. Jan 2026, 14:57
Wenn ihr per USB Parameter die Bildmodi aufhellt beachtet UNBEDINGT den Satz dass ihr immer nur einen Bildmodus auf einmal aendern sollt!
Das kann euch sonst die komplette DV engine zerhauen (Quelle avforums)
Jogitronic
#4938 erstellt: 18. Jan 2026, 15:50
Was hast du denn da eingestellt? Oder benutzt du die Voreinstellung?
Bei welchen konkreten Bildinhalten siehst du das?
Ich schlage ja immer wieder diese Einstellungen vor und das Bild ist damit immer noch akzeptabel "natürlich".
Beispiele:
(so gut wie möglich mit dem Handy fotografiert ...)
DV FMM
DV Lebhaft
DV FMM
DV Lebhaft
Litefor
#4939 erstellt: 18. Jan 2026, 16:03
Also DV FMM finde ich ganz klar besser als lebhaft, sieht man auch sehr schön auf den Fotos von Jogitronic.
Ich habe eine sehr ähnliche Einstellung für DV wie Jogitronic, mit ein paar Abweichungen:
BILD via Apple TV 4K
>Modus DV Filmmaker Mode
>Format Original - Just Scan
>Erweitert >>Helligkeit
Helligkeit OLED-Pixel 100
Kontrast anpassen 100
Schwarzwert 50
Automat. Dyn. Kontrast Aus
Ausdrucksverstärkung Details
Größte Helligkeit Hoch
Gamma 2.2 (ist ausgegraut)
FMM Umgebungslicht Ein
Near Black-Details 0
Automat. Helligkeit Aus
>Erweitert >>Farbe
Farbtiefe50
Farbumfang Ursprünglich (ist ausgegraut)
>Erweitert >>Farbe >>Feineinstellg.Aus
>Erweitert >>Farbe >>Weißabgleich
FarbtemperaturWarm 40
>Erweitert >>Klarheit
Schärfe anpassen 0
Echtes Kino Ein
TruMotion Filmische Bewegung
>Erweitert >>FMM Auto-Start Ein
nimsa67
#4940 erstellt: 18. Jan 2026, 16:17
Naja, ich verstehe Leute die sich über einen zu dunklen bzw. Details verschluckenden DV FMM aufregen schon.
Auf dem Bild mit dem Frosch sieht man es prinzipiell ganz gut: der Ast auf der rechten unteren Seite ist im FMM gar nicht mehr als Solcher erkennbar - ganz zu schweigen von der Maserung.
Mir ist schon klar dass das jetzt auf den Bildern eine Spur „verschärft“ aussieht … aber grundsätzlich ist damit wunderbar gezeigt wenn manche von „verschlucken“ im Schwarz oder im weitesten Sinne Blackcrush erzählen.
*chiefsteve*
#4941 erstellt: 18. Jan 2026, 16:34
yap...bei den erbeeren links ...spiegelung ist weg im FMM
[Beitrag von *chiefsteve* am 18. Jan 2026, 16:39 bearbeitet]
Jogitronic
#4942 erstellt: 18. Jan 2026, 16:55
iTunes/Apple TV, MM Fury Road, Laufzeit 12:57 (edit: korrigiert)
ATV 4K = 966 Nits
Interne App = 638 Nits
Also da scheint es diesbezüglich keine relevanten Änderungen /Verbesserungen gegeben zu haben.
Hier denn noch mal aktuelle Messungen, jeweils FMM / Kino-Home, / Lebhaft
Interne App: 630 / 988 / 1250 Nits
ATV 4K: 967 / 967 / 1790 Nits
Der angesproche "Kino-Home" Bildmodus ist in dem Fall ungefähr gleich hell. Ob es da beim letzten Update eine Änderung gab, kann ich nicht sagen.
Das bei externer Zuspielung der FMM und Kino-Home gleich hell sind täuscht, denn das trifft nur auf den verwendeten Bildausschnitt zu. Der "Rest" des Bildes wird schon deutlich aufgehellt wenn man Kino-Home verwendet.
Litefor
#4943 erstellt: 18. Jan 2026, 17:03
Naja, das liegt nun im wahrsten Sinne im Auge des Betrachters.
Die Spiegelung der Erdbeere links ist im FMM sehr wohl noch da, nur halt wesentlich schwächer. Die Erdbeere rechts ist in der Spiegelung bei lebhaft hingegen so überzeichnet, dass man schon fast nicht mehr erkennen kann, dass es sich nur um eine Spiegelung handelt.
Es kommt also stark auf die subjektive Präferenz an. Ich komme von einem Sony KD55-A1, der nach 8 Jahren eine extrem viel niedrigere Helligkeit hatte als mein jetziger G5. Im Vergleich dazu sind alle Szenen taghell...
Jogitronic
#4944 erstellt: 18. Jan 2026, 17:07
STOPP !!
Ihr könnt nicht solche Details meinen unprofessionellen Bildern entnehmen. Ich habe lediglich versucht den Farbeindruck einzufangen und mein Handy schafft das trotz "Pro" Bildmodus nicht besser.
Wer sich dafür interessiert oder z.B. überzogene Farben hat, möge dies bei eigenen Inhalten und meinen Einstellungen mal ausprobieren. Wie schon geschrieben, finde ich das in Realität ganz akzeptabel.
[Beitrag von hgdo am 19. Jan 2026, 20:02 bearbeitet]
JamX
#4945 erstellt: 18. Jan 2026, 23:08
Danke vielmals für die interessanten Messungen - nur damit ich es richtig einordne und verstanden habe (weil ich das noch nicht wusste):
Interne Apps sind in DV dünkler als externe Zuspieler (wie hier ATV) - könnte das eventuell auch für Nvidia Shield gelten? Oder ist da eher ATV im Vorteil?
Und interne Apps sollte man eher meiden und externe Zuspieler bevorzugen beim Streaming?
Jogitronic
#4946 erstellt: 19. Jan 2026, 00:57
Schau es dir an:
Zumindest beim G5 trifft das zu
ehl
#4947 erstellt: 19. Jan 2026, 01:06
Es gilt soweit ich weiß übergreifend für alle DV Inhalte, welche mit MDL=4000 nits gemastert wurden, weil es sich um einen lg spezifischen Bug handelt, welcher schon seit min. 2022 existiert.
https://www.avsforum.com/posts/64166001/
Da DV bei professionellen Tests aber weitestgehend unberücksichtigt bleibt, werden Nutzer und auch LG nicht gezielt darauf aufmerksam
LG reagiert zwar meist auf Kritik, aber bis dahin wird dann auch gerne erstmal abgewartet
[Beitrag von ehl am 19. Jan 2026, 01:28 bearbeitet]
Jogitronic
#4948 erstellt: 19. Jan 2026, 01:10
Dolby Vision verwendet beim Streaming das sogenannte Profil 5.
Hier noch mal ein Video mit diesem Profil und einem Vergleich von ATV und Shield:
Stn91
#4949 erstellt: 20. Jan 2026, 15:06
Ich habe gerade bemerkt das der Rand auf dem Display links, ein Stück breiter ist als rechts.
Unten ist der ja eh dicker als oben, aber das rechts ist mir jetzt erst aufgefallen, liegt das an dieser Pixelverschiebung ?
Weil wenn nicht, kann ich damit nicht weiter klarkommen 😵‍💫
Bin schon überglücklich das ich kein banding wahrnehmen kann, also durch diese testvideos, würde ihn ungern umtauschen müssen.
LG G5 77er
[Beitrag von Stn91 am 20. Jan 2026, 15:06 bearbeitet]
nimsa67
#4950 erstellt: 20. Jan 2026, 15:10
Ja, das ist die Pixelverschiebung. Nach einigen weiteren Betriebsstunden sieht es dann wieder minimal anders aus usw.
Stn91
#4951 erstellt: 20. Jan 2026, 15:35
Ich danke dir✌️
Leon7791
#4952 erstellt: 20. Jan 2026, 16:00
Ich habe bei meinem G5 DV von der internen App vs firetv 4K verglichen und messe keinen unterschied bei Netflix
Kann aber sein das alle Filme in Netflix nur 1000nit gemasterd sind. Habt ihr einen Film auf Netflix/Prime der in dv ist und 4000nit gemasterd ist?
ehl
#4953 erstellt: 20. Jan 2026, 17:56
Der hinterlegte MDL Wert ist entscheidend, also eigtl. nur die Maximalhelligkeit des im Mastering verwendeten Monitors.
nein, definitiv nicht, die streamingdienste begrenzen nicht die Spitzenhelligkeit des jeweiligen Films
Jogitronic
#4954 erstellt: 20. Jan 2026, 18:09
Auch wenn das technisch nicht begrenzt ist, wird das praktisch nicht verwendet.
Das ist interessant
Ich glotze deswegen mal aus meiner Wunschliste den Film "Against The Ice", denn da gibt es jede Menge helle Szenen. Anschließend messe ich auch mal die Unterschiede zwischen den Geräten.
[Beitrag von Jogitronic am 20. Jan 2026, 18:10 bearbeitet]
Jogitronic
#4955 erstellt: 20. Jan 2026, 20:11
So, es wird noch interessanter ...
Testgeräte:
1) Fire TV Stick 4K (nicht Max)
2) Apple TV 4K (1.Generation)
3) G5 - Interne App
Nits in den Bildmodi:
FMM / Kino-Home / Lebhaft
(mit meinen genannten Einstellungen)
Die Testszene ist bei Laufzeit 17:18
Ergebnisse (gerundet):
1) Fire = 500 / 550 / 880
2) ATV = 290 / 340 / 630
3) Intern = 300 / 470 / 990
Also bei dem Bildmaterial ist der Fire TV Stick schon sichtbar heller als das ATV 4K ?!
Das ATV ist im FMM etwa so hell wie die interne App, aber in den anderen Bildmodi am dunkelsten.
Die interne App liegt im Mittelfeld, bietet aber in Lebhaft die höchste Helligkeit.
Tja, da sind ja diverse Ungereimtheiten vorhanden und eine Frage steht im Raum - Was ist richtig / korrekt?
Der Haken an der Sache ist, dass das hellste Gerät im FMM nicht unbedingt das "beste" Gerät sein muss. Manche Szenen fand ich nämlich schon sehr hell mit dem Fire Stick, das könnte auch schon heller als vorgesehen sein??
Jetzt ist ein HDR10 Vergleich notwendig um das mal weiter zu erforschen. Welcher Film auf Netflix läuft denn "nur" in HDR10
Jogitronic
#4956 erstellt: 20. Jan 2026, 20:32
Auch interessant ...
ehl
#4957 erstellt: 20. Jan 2026, 21:16
Zmdst. beherrscht der firetv4k stick kein echtes TV-led DV
DV-testmaterial inkl. Angaben zur Zielhelligkeit sollte doch von HDR-Dissector mittlerweile zur Verfügung gestellt worden sein?
Bringt ja nichts, hier jedes mal raten zu müssen
Ansonsten schreib ich ihn vielleicht mal an
[Beitrag von ehl am 20. Jan 2026, 21:21 bearbeitet]
Leon7791
#4958 erstellt: 21. Jan 2026, 03:56
Testgeräte:
3) G5 - Interne App
Jetzt ist ein HDR10 Vergleich notwendig um das mal weiter zu erforschen. Welcher Film auf Netflix läuft denn "nur" in HDR10 :?
Habs so eben bei mir gemessen sowohl mit dem Fire Stick 4K als auch mit der internen App komme ich auf 850nits. Komplett identische Werte. Ich muss dazu aber sagen das ich den DBrightness Trick mit der USB Software habe das alle DV Inhalte extern oder Inter intern aufhellen kann. Allerdings bezweifle ich das es daran liegt. Ich vermute das du irgend einen Fehler machst. Hast mal geschaut ob eventuell irgendwo Einstellung nicht Match? Zb Helligkeitssensor aktiv oder so?
Jogitronic
#4959 erstellt: 21. Jan 2026, 11:36
Danke für die Rückmeldung. In welchem Modus hast du die 850 Nits?
Das dachte ich auch, kann aber keinen offensichtlichen Fehler finden.
Die Einstellungen sind in den jeweiligen Bildmodi identisch, da ich grundsätzlich "Auf alle Eingänge verwenden" verwende.
ATV und Stick sind zusätzlich mit einem Switch am gleichen Eingang angeschlossen. Ich habe die aber auch mal direkt am gleichen Eingang angeschlossen, um einen Fehler durch den Switch auszuschliessen.
Helligkeitssensor ist nicht aktiv, bzw. nur der Filmmaker Umgebungslicht. Das spielt aber auch keine Rolle, da der Raum abgedunkelt ist. In den anderen Modi ist der ja gar nicht aktiv.
Danke auch für diesen Hinweis.
Da ich keine Fehler beim Testsetup erkennen kann, schließe ich daraus, dass die Unterschiede Geräte bedingt sind. ATV und Stick sind ältere Generationen und zumindest beim ATV meine ich, dass da bei DV auch mal etwas geändert wurde?
Den neueren Fire TV Stick 4K Max habe ich verkauft, weil der in machen Szenen dunkler als die interne App war. Also "neuer" muss nicht unbedingt besser oder fehlerfrei sein.
Aber kann Player-LED solche großen Unterschiede ausmachen?
Zumindest in Vincents Beispiel war der Modus z.B. dunkler und nicht heller.
Insgesamt finde ich das sehr unbefriedigend, denn im Zeitalter der digitalen Übertragung sollte das Ergebnis immer gleich sein.
Jogitronic
#4960 erstellt: 21. Jan 2026, 12:17
So, während ich das geschrieben habe kam ich auf die Idee, das mal an meinem A90J zu messen.
ATV und Stick waren ohne Splitter am gleichen Eingang angeschlossen.
Bildmodus DV Dunkel. Die Einstellungen sind identisch, das habe ich überprüft.
Ergebnisse:
Interne App = 230 Nits
ATV 4K = 230 Nits
Fire Stick = 190 Nits
Also wie schon beim G5 ist der akurate Bildmodus (beim G5 Filmmaker) bei ATV und interner App identisch. Der Fire Stick ist aber an diesem TV dunkler und nicht (deutlich) heller.
Mein Fazit:
Dolby Vision ist eine "Spielwiese". Je nach Gerätekonstellation hat man unterschiedliche Ergebnisse . Gerade das soll DV ja nicht machen, denn die versprechen eine optimale Anpassung an die Fähigkeiten des jeweiligen TV.
Tja, das ist mal wieder der Unterschied zwischen Theorie und Praxis ...
nimsa67
#4961 erstellt: 21. Jan 2026, 12:41
Das würde dann auch die unterschiedlichen Meinungen bzgl. DV Content ist deutlich zu dunkel wenigstens etwas erklären. Natürlich abgesehen vom jeweils persönlichen Geschmack/Wahrnehmung.
Eine minimal andere Geräte - Konstellation führt speziell bei DV anscheinend zu doch erheblich unterschiedlichen Ergebnissen … so sollte das natürlich definitiv nicht sein.
Jogitronic
#4962 erstellt: 21. Jan 2026, 12:55
Bei mir steht auch der Kauf des kommenden ATV an. Jetzt weiss ich jedenfalls, was ich zuerst testen werde ...
Leon7791
#4963 erstellt: 21. Jan 2026, 12:58
Trotzdem strange ich kann den fehler bei mir nicht finden. Fire tv und interne app sind bei mirnidentisch hell. Habe jetzt the witcher, altered carbon und weitere serien getedtet alles identische werte im filmmakermode
Jogitronic
#4964 erstellt: 21. Jan 2026, 13:18
Haben wir denn exakt den gleichen Stick?
Bei mir steht unter Info "Amazon Fire TV Stick 4K (1.Generation)"
Fire OS 6.7.1.1
[Beitrag von Jogitronic am 21. Jan 2026, 13:25 bearbeitet]
lude1605
#4965 erstellt: 21. Jan 2026, 13:25
Tonaussetzer LG 83G5 und AVR Denon 4800 über HDMI aber ohne eARC zu aktivieren. Bei der APP Disney und DAZN z.B, gestern die Fussballkonferenz. Hat das noch jemenad ? Gibt es Lösungen? Immer mal wieder setzt der Ton für ein paar millisekunden aus - das nervt. Habe den TV neu gestartet und den AVR Denon auch wegen evtl.HDMI Handshake Probleme - hat leider nicht geholfen. Ein anderes Kabel hab ich auch schon versucht.
ehl
#4966 erstellt: 21. Jan 2026, 14:27
Das weiß ich nicht, allerdings nutzt der firetv 4k stick nicht mal zwingend player-led DV, sondern eine Art fake-tv-led
https://youtu.be/eQ9SOMlX0AI
Wollte auch lediglich darauf hinweisen, dass sich das DV Wiedergabesignal von firetv und appletv stick schon mal grdstzl. unterscheiden.
ATV 4K = 230 Nits
Der LG Bug tritt eh nur bei MDL=4000 bzw. MDL >1000nits auf, man müsste den MDL Wert des DV Streams erstmal kennen.
Jogitronic
#4967 erstellt: 21. Jan 2026, 17:24
Dolby Vision hat halt viel zu viele Optionen und die Resultate unterscheiden sich nicht nur in Nuancen, sondern teilweise sehr deutlich. Sorry, aber da nehme ich lieber "nur" HDR10 und habe eine weitestgehend konstante und reproduzierbare Wiedergabe.
Hier noch mal ein Video zu dem Thema:
Dolby Vision Fake TV-LED vs True TV-LED vs LLDV Comparison - Chromecast GTV - LG C2 - Sony X800m2
In der Beschreibung steht dazu:
Devices: Sony X800m2, Chromecast GTV, and LG C2...
Test file: Profile 5 DV with a 100nits L2 trims. 1000nits grade...
There's definitely a difference between fake TV-led and LLDV.
LLDV is brighter and red looks more saturated than fake TV-LED.
There's a noticeable difference between fake TV-led and true TV-led.
C2 internal app and X800m2 TV-led look pretty much identical in most of the shots.
LLDV brightness looks closer to true tv-led.
Fake TV-led colors look closer to true tv-led.
Er hat auch noch diverse andere Videos zu den Problemen / Unterschieden gemacht - falls euch das interessiert.
Als praxisorientierter Anwender steige ich an der Stelle aus, denn das zusätzliche Wissen hilft mir nicht weiter, da ich das ja doch nicht beeinflussen kann.
Ich wundere mich jetzt bei Dolby Vison über nichts mehr, teste neue Geräte mit solchen Szenen und lasse mich überraschen ...
rudisilves
#4968 erstellt: 21. Jan 2026, 18:01
Wenn ich jetzt noch einen G5 kaufe, wie kamn ich bei einer Onilne Bestellung prüfen, wann das Gerät gebaut wurde, dh .aus welcher Charge.es kommt.?
Da ein C6 H bald auch auftaucht, könnte ein G5 eine Alternative sein, wenn man einen neuen TV kaufen möchte .
ehl
#4969 erstellt: 21. Jan 2026, 23:22
Gesagt, getan
https://drive.google...9P1wgzpARlJWcWoliuQ4
Man wähle dort die "woman dress DV MDL=4000 nits und MDL=1000 nits version zum Download aus und überprüfe die angegebene "bottom square -maxCLL" Helligkeit in der gewünschten Szene mit einer Messung des kleinen Quadrats unten links.
Empfehlenswert sind hier Szenen mit nicht allzu hohen Werten, 100-500 nits genügen.
Bis 200 nits kann man auch direkt die stets eingeblendeten Helligkeitsstufen messen ohne erst zur jeweiligen Szene skippen zu müssen.
Es handelt sich um DV profil 5
Nun muss man auch nicht mehr raten, welches Gerät den Helligkeitswert korrekt widergibt
Jogitronic
#4970 erstellt: 22. Jan 2026, 11:02
Äh - wie spiele ich diese Datei mit ATV oder Stick ab?
LG OLED 2024 - B4 α8/evo C4 α9/evo G4, M4 mit MLA α11/ SIGNATURE T/ 42-97\"
celle am 11.10.2023  –  Letzte Antwort am 03.12.2024  –  3491 Beiträge
LG Oled evo Rückseite
maik2244 am 30.09.2022  –  Letzte Antwort am 30.09.2022  –  2 Beiträge
LG Oled 3 evo besser als OLED65G19LA ?
octopussy9 am 17.09.2023  –  Letzte Antwort am 18.09.2023  –  2 Beiträge
Interessanter Vergleich LG OLED G1 evo mit Sony A90J OLED
schnackl am 12.07.2021  –  Letzte Antwort am 20.07.2021  –  5 Beiträge
LG OLED 2023 - A/B/evo C/evo G + Z mit MLA/evo M3 wireless | 4K 42-97"/ 8K 77-88"
celle am 27.09.2022  –  Letzte Antwort am 10.11.2024  –  4668 Beiträge
LG OLED evo G4 mit Magic Remote Premium steuern
Bedor am 30.09.2024  –  Letzte Antwort am 30.11.2024  –  5 Beiträge
LG OLED 55 G1 EVO kein Digital Ton am Opt.Ausgang
lukobimmel am 30.05.2021  –  Letzte Antwort am 05.09.2022  –  27 Beiträge
LG gallery EVO Wandhalterung
Kardi am 05.01.2022  –  Letzte Antwort am 05.01.2022  –  2 Beiträge
LG OLED 42 Zoll
Willi_9 am 26.07.2021  –  Letzte Antwort am 21.09.2022  –  21 Beiträge
LG OLED evo 55G1 Verformung? Abdeckung löst sich?
FloRida272 am 11.12.2021  –  Letzte Antwort am 27.12.2021  –  4 Beiträge
  • Registrierte Mitglieder931.200 ( Heute: 4 )
  • Neuestes MitgliedFlospiegelb_
  • Gesamtzahl an Themen1.564.940
  • Gesamtzahl an Beiträgen21.872.790
