| HIFI-FORUM » English » Stereo (Engl.) » +/- db | |
+/- db+A -A |
SUB_BOSS
Gesperrt |
erstellt: 11. Mrz 2005, 11:01
n what way are the +/- db ratings significant in frequency response ratings.........
Arj
erstellt: 11. Mrz 2005, 11:29
Let me see if I can explain this, and if my understanding on this is correct. it basically means variation in loudness ie deviation from a "flat response" -Suppose u are hearing a tone the same loudness from say 10Hz to 40Khz and your speaker has a response rated at 40Hz to 20Khz +/- 3db since the speaker will not have a flat response, it will reproduce this sound with differnce output levels at different freq. hence a average person will start making out that the loudness is dipping from below 40Hz onwards... (an average person is just able to make out the difference of 3dB of difference in a sound) that is why the 10db point is also important as that is the point at which a sound volume will halve hence two speaker may have the same response at3db from 40 to 20. but one may drop sgharply to a 10db point at 35Hz hence inaudible sound below that..while another may have its 10dB point only at say 28Hz..hence it goes down lower.. Hope I have been clear in teh above ! |
ravi
erstellt: 11. Mrz 2005, 16:46
Clasically, frequency response bandwidth is defined as the frequency extremes at which the outputs drops by 3dB from its value at mid-band or passband,as it gently rolls off (imagine a bow response). Applied to speakers as far as I understand, the +/- dB levels define the cutoff power points that are considered as the limit of usable bandwidth. So if a speaker response is specifiedd as "45Hz to 20KHz, +1dB/-3dB", then it means the output is down by 3dB at 45Hz and 20KHz as compared to midband flat response and also there could be a peak of upto +1dB at some intermediate points - so the power output could vary as much as 4dB within the 45Hz to 20KHz band. |
Pulz amp-preamp Ratings!!? neckie am 23.02.2005 – Letzte Antwort am 26.02.2005 – 18 Beiträge |
Frequency Response juggy_25 am 29.06.2006 – Letzte Antwort am 05.07.2006 – 19 Beiträge |
Is the power ratings on AVR - 100 into 6 channels true.?? SUB_BOSS am 12.01.2005 – Letzte Antwort am 12.01.2005 – 4 Beiträge |
frequency range filmguy am 15.02.2005 – Letzte Antwort am 16.02.2005 – 10 Beiträge |
What music do you use to test for Bass Response ? Arj am 25.12.2005 – Letzte Antwort am 29.12.2005 – 11 Beiträge |
who specifies the TRUE RMS ratings even some big bees dont.. Sonic_Master am 08.12.2005 – Letzte Antwort am 19.12.2005 – 12 Beiträge |
What are Martin Logan Sequel IIs worth? revnice am 15.04.2004 – Letzte Antwort am 22.04.2004 – 2 Beiträge |
What is the best way to clean your woofer cones ? square_wave am 27.09.2006 – Letzte Antwort am 11.10.2006 – 23 Beiträge |
What Hi-Fi: Only Roses, Where are the Thorns? Neutral am 12.09.2006 – Letzte Antwort am 15.09.2006 – 8 Beiträge |
speaker sensitivity TROJAN_HORSE am 04.03.2005 – Letzte Antwort am 04.03.2005 – 6 Beiträge |
2005
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder931.200 ( Heute: 1 )
- Neuestes Mitgliedstarfighter006
- Gesamtzahl an Themen1.564.929
- Gesamtzahl an Beiträgen21.872.383
