problem with Telefunken CR100
stevenrob
#1 erstellt: 17. Dez 2016, 23:20
Hello, I'm a french people and sorry I speak Deutsch very, so I try English.
I have a problem with this boombox that I just buy.
When I plug it to AC and I put radio or cassette : the boombox works 5 seconds and stops. I Have changed the electrical transformer but no change. Have you an idea ?
Best regards
kadioram
#2 erstellt: 18. Dez 2016, 12:57
does it work when you use batteries (=DC)? If yes, you have probably a problem with your power supply (faulty soldering connections, broken rectifier diodes, worn out charging capacitors...)
If it won´t work with batteries, the variety of faults can be very wide spread...
I recently reworked a little "boombox" (not really "BOOM", a Sanyo ROBO), with the same fault. There had been some faulty soldering connection and worn out charging capacitors.
After resoldering and a complete recapping it worked again.
[Beitrag von kadioram am 18. Dez 2016, 13:05 bearbeitet]
stevenrob
#3 erstellt: 19. Dez 2016, 00:55
Hello, you're right. With DC, all works fine. Could you show me with internet links the sort of resistor I must change ? I have the service manual but I'm novice in electronic.
Best regards
kadioram
#4 erstellt: 21. Dez 2016, 15:44
Hello,
it would be helpful, if you could post some images of the circuit board.
You can order parts at www.conrad.fr for example. The category is composants passifs
BR
[Beitrag von kadioram am 21. Dez 2016, 15:47 bearbeitet]
stevenrob
#5 erstellt: 21. Dez 2016, 17:52
P1080337
Hello,
I have changed 1,2 et 3 but no change. I will change the 4 (http://www.ebay.fr/itm/322180064215?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT).
Best regards
Rabia_sorda
#6 erstellt: 21. Dez 2016, 23:02
Check the rectifier diodes, resistors and transistors in the power supply. The transistor (4) is a good idea.
At the power plug socket should be a switch which also check. Does the voltage at the secondary output of the transformer remain, or does it collapse?
Also look for bad solder joints.
[Beitrag von Rabia_sorda am 21. Dez 2016, 23:04 bearbeitet]
stevenrob
#7 erstellt: 30. Dez 2016, 09:12
Hello, I have changed transistor number 4 and now the boombox works fine.
Thanks for your help guys
Best regards
Rabia_sorda
#8 erstellt: 30. Dez 2016, 14:37
Fine!
Telefunken CR100 verschiedene Probleme
SebW am 10.10.2020  –  Letzte Antwort am 23.11.2020  –  7 Beiträge
Telefunken Studio M1 defekt
stevenrob am 08.02.2017  –  Letzte Antwort am 22.02.2017  –  5 Beiträge
Telefunken TL70 renovieren
arusha am 07.04.2015  –  Letzte Antwort am 10.04.2015  –  7 Beiträge
Telefunken 5031 Lautstärke-Problem
Lonelywolf33 am 08.12.2011  –  Letzte Antwort am 21.12.2011  –  6 Beiträge
Telefunken Tuner
ToplineVR6 am 15.10.2013  –  Letzte Antwort am 28.10.2013  –  3 Beiträge
Telefunken Stp
franzel28 am 04.12.2009  –  Letzte Antwort am 06.12.2009  –  6 Beiträge
Telefunken HA850
Mr.T.GO am 22.04.2020  –  Letzte Antwort am 21.05.2020  –  9 Beiträge
MAGNETOPHON 3000 HIFI TELEFUNKEN UMSCHALTER VORBAND/HINTERBAND
GIORGIO_MARTINI am 01.08.2020  –  Letzte Antwort am 01.08.2020  –  3 Beiträge
Problem mit Telefunken RA 200
Segelflieger85 am 15.04.2012  –  Letzte Antwort am 15.04.2012  –  7 Beiträge
Telefunken 6001 Rumpel-Schalter-Problem
volker225 am 31.05.2013  –  Letzte Antwort am 01.06.2013  –  3 Beiträge
2016
  • Registrierte Mitglieder931.107 ( Heute: 1 )
  • Neuestes Mitgliedkxlas
  • Gesamtzahl an Themen1.564.735
  • Gesamtzahl an Beiträgen21.864.591
