| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Sony ta f707es modifications | |
Sony ta f707es modifications+A -A |
Bamber1_
erstellt: 27. Feb 2026, 22:20
I have a sony ta f707es German model but it sounds very restrained compared to the European specification model is it possible to convert it to give a better sound thanks for your help.
Rabia_sorda
erstellt: 27. Feb 2026, 22:41
The German model likely has capacitors in the line signal (RCA jacks) due to the FTZ regulations of the time. Therefore, compare the schematic with a non-European device and modify your device accordingly. It's also possible that only the coupling capacitors in the signal paths have dried out. |
Bamber1_
erstellt: 27. Feb 2026, 22:46
Thank you I see quite a lot of differences i was wondering if anyone had done the modification in the past and knew what the the main capacitors that needed changing or removing to improve the sound as there seems a marked difference in sound the European model sounds so musical much more forward sounding. |
Rabia_sorda
erstellt: 27. Feb 2026, 23:02
The ceramic capacitors located in the immediate vicinity of the RCA jacks are due to the former FTZ (Telecommunications Technical Center for Telecommunications Equipment in Germany (Radio interference suppression) ). Beyond that, there should be no differences. |
Poetry2me
erstellt: 02. Mrz 2026, 02:52
Find the Service Manual (SM) for the amp, e.g. search for "Sony TA-F707ES SM PDF" and look up the schematic. In the schematic you will find described the parts which are different depending on market or model which may need modification. ![]() ![]() Main focus should be on the parts near the phono input cinch / RCA, which need to be removed and replaced with one wire. - Johannes [Beitrag von Poetry2me am 02. Mrz 2026, 13:15 bearbeitet] |
Poetry2me
erstellt: 02. Mrz 2026, 09:37
You can register on the image hosting site using your email address. This allows you to download the image in highres. The areas marked in blue are added components that can be removed. In case of the input filters, these additional components must be replaced with a wire jumper, one for the left and one for the right channel. The components marked with a star (and in green underlay by me) have changed values. See tables contained in this schematic. They show three different variants: Two amp models (707 and 808) and the Germany version (according to FTZ regulations in place at that time). When targeting the phono equalizer, the most important measure is to remove the phono input filter, which is located near the phono RCA jacks on the input board. As described, one wire jumper must be installed per channel after removing the components. This single measure should have the biggest effect and works very well on many classic amps from this era, across all manufacturers. Hope this helps. - Johannes [Beitrag von Poetry2me am 02. Mrz 2026, 13:05 bearbeitet] |
Bamber1_
erstellt: 02. Mrz 2026, 22:31
Thank you will start the modifications I have two ta f707es but one has a blown output transistors but I do have a damaged ta f770es but it does have a good main board are they a straight swap it would save a lot of fault finding and of cause the transistors are unobtainable thanks for your help. |
Poetry2me
erstellt: 03. Mrz 2026, 00:40
OK, all of these models use the famous VFET output transistors. What ever you do with these amps, first of all make sure you swap ALL fuse resistors in them against regular resistor types. These FR are one of the main reasons why so many of the marvelous VFET transistors have died. FR age badly and often change value before finally burning through. Many VFET had to run very hot for long before the FR finally failed. When exchanging VFET between amps, do it pair-wise. These should be selected pairs to keep distortion low. Whether it is possible to use a complete PCB from one model in another model, honestly I don't know. The schematic certainly looks very similar. - Johannes |
Sony TA-F707ES Kopfhörerbuchse gesucht Murmeltier8 am 05.02.2022 – Letzte Antwort am 17.04.2022 – 12 Beiträge |
Sony TA F707ES nach einschalten defekt. Hilfe! Alex_69 am 20.02.2021 – Letzte Antwort am 10.05.2023 – 33 Beiträge |
Sony TA-F707ES keine 5V am Infrarot Empfänger MikeDee am 06.01.2013 – Letzte Antwort am 11.01.2013 – 19 Beiträge |
Sony Esprit TA-N88B 7rm7 am 15.03.2007 – Letzte Antwort am 16.03.2007 – 4 Beiträge |
Endstufe Sony TA-N55ES Mäuserich am 10.04.2007 – Letzte Antwort am 10.04.2007 – 4 Beiträge |
Sony TA-F470 Verstärker berndbloed am 29.07.2007 – Letzte Antwort am 29.07.2007 – 2 Beiträge |
SONY TA-N 86B Audire500 am 21.11.2007 – Letzte Antwort am 21.11.2007 – 2 Beiträge |
Sony TA-515 Transistoren? mbkossi am 02.01.2008 – Letzte Antwort am 03.01.2008 – 3 Beiträge |
Sony TA-3650 kaputt? BMW777 am 26.02.2008 – Letzte Antwort am 26.02.2008 – 3 Beiträge |
Sony TA-F417R hermannxxl61 am 24.12.2008 – Letzte Antwort am 07.01.2009 – 7 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder931.071 ( Heute: 1 )
- Neuestes MitgliedTackleberry_
- Gesamtzahl an Themen1.564.606
- Gesamtzahl an Beiträgen21.859.708
