| HIFI-FORUM » Car-Hifi » Car-Hifi: Allgemeines » Elektronik » U.S.AMPS USA50 | |
U.S.AMPS USA50+A -A |
Jogi_Bär
erstellt: 28. Okt 2003, 21:58
hi leute ich hab die USAMPS USA50 eingebaut (betreibe damit ein 16er 2wege System)jetzt habe ich gehört das dieser Amp auch für einen Subwoofer geeignet wäre und mit dem 16er total unterfordert ist.Ich habe leider kein Datenblatt von dem Gerät(wäre toll wenn mir das einer mailen könnte) danke schon mal
DE_HOO
erstellt: 28. Okt 2003, 22:15
Manufacturer: Product Type: Physical Specifications: Weight: Material: End plates: Bottom Plate: Circuit Board: Crossover: Signal Path Components: Rated Amplifier Output @ 4 Ohms per Channel: USA-50: 50x: Amplifier Overage Factor: USA-50: 50x: Output Signal Delivery: External Speaker Connections: U.S. Amps Inc. Bridgable two-channel audio amplifier with built-in 2-way electronic crossover and preamplifier output. Size: 2.1" H X 7.5" W X 7.75" L (including terminals) 7lbs. Heat Sink: Bead-blasted anodized 60/63 aircraft aluminum alloy, T-6 temper. Laser-etched U.S. Amps logo. .062" painted steel. .125" clear Plexiglas. Mil-spec FR-4 double-sided plated through 2 ounce SMOBC. (so The full Butterworth 2-way fixed frequency crossover can output either high or low pass signals to a second amplifier at 100z with an 18 db per octave slope in high-pass stereo, or a 24 db per octave slope in low pass mixed mono. The crossover can be defeated to allow full range input and output. All polypropylene capacitors and 1% tolerance resistors. 50 Watts 100 Watts 10:1 5:1 All high level signals run parallel to the circuit board ground plane for maximum RF rejection. There are no above-board speaker connections. Via heavy duty goldplated 10mm barrier terminal, circuit board mounted and end plate reinforced. Amplifier Circuit Topology: ) there! Input: Ground-reinforced dual gold-plated RCA jacks. Input- The left channel is inverted using a lownoise high-speed op amp to allow for convenient bridging or stereo / mixed-mono operation. Four 125 watt 3MHz bipolar transistors. (500 watts) Phase Inversion: Output Components: Number of Channels: Potentiometers: Operation: Amplifier Filtering: Power Rails: USA-50: 50x: Drivers: 2 isolated to effectively eliminate ground loops and subsequent system noise. A built-in voltage dividing network will accept high and low level signal from nearly any source, including most OEM and highpowered BTL units. Sealed custom-built 7mm linear taper. Water and dust-proof. Class A-B utilizing isolated triple darlington dual-differential pairs with complementary-symmetry outputs. 4,000mfd 15 Volts 24 Volts Matched triple darlington configuration. Power Supply: Power Requirements: Input Filtering: Transformer: Oscillation Frequency: Pulse Components: Power Supply Output Current: USA-50: 50x: Overage Ratio: USA-50: 50x: Smart Amp Technology Non-regulated Ultrafet. 10-15 volts DC. Over and under voltage protected. 3,000mfd low ESR capacitors. Hand-wound 1.25" ferrite with solid copper 14 gauge primary and 16 gauge secondary windings. 37KHz Four 75 amp 60 volt Ultrafets. (300 amps) +/- 15 Volts @16 Amps +/- 24 Volts @ 12 Amps 15:1 12.5:1 Protection: Both models incorporate a noncomputerized version of SAT, (U.S. Amps exclusive ) that precisely monitors each amplifier channel, the battery voltage and amplifier temperature. In the event of a fault condition, SAT will activate to protect the amplifier from damage. SPECIFICATIONS: Watts per Channel Bridged Output: THD: S/N Ratio: Frequency Response: Fuse: USA-50 50X (pictured) 4 ohms: 25 Watts 50 Watts 2 ohms: 50 Watts 80 Watts 1 ohm: 80 Watts N/A 160 Watts 160 Watts @ 2 Ohms @ 4 Ohms <.006% <.006% >100db >100db 5Hz-50KHz 5Hz-50KHz 25 Amps 25 Amps Copyright 1999 U.S. Amps Inc. All Rights Reserved. Specifications subject to change without notice. U.S. Amps Inc. 7325-100 NW 13th Blvd. Gainesville, Florida, 32653. (352)338-1926 fax (352)371-4122 www.usamps.com 1999 USA-50 and 50x Technical Information by TM Vielleicht reicht dir das ja sorry das ich des net auf Deutsch da hab!!!! Also als Subtriebwerk ist sie zu schwach!!! Da das ein wenig durcheinander ist hier noch nen Link wo du des auch nochmal lesen kannst!! http://www.usamps.com/technical/pdf/wp50_99.pdf Gruß DE_HOO [Beitrag von DE_HOO am 28. Okt 2003, 22:17 bearbeitet] |
Jogi_Bär
erstellt: 28. Okt 2003, 23:16
ich glaube das,das nicht die Endstufe ist die ich habe weil meine auch einwenig anders ausschaut ist war scheinlich auch schon ein paar Tage älter da sind nähmlich die Stromkabel noch in der Endstufe verlötet.die Form von dem Kühlkörper ist die Gleiche.Hab mich mal auf der Seite bischen um gekuckt aber leider nichts gefunden. aber trotzdem danke |
maximal 400W rms und 16er? FallenAngel am 18.09.2004 – Letzte Antwort am 22.09.2004 – 41 Beiträge |
Konfiguration Soundstream 4640 10er Coax/16er Kickbass poisi am 12.12.2004 – Letzte Antwort am 14.12.2004 – 13 Beiträge |
Großes Problem mit USAMPS - HILFE! Jimbo195 am 31.07.2009 – Letzte Antwort am 09.08.2009 – 12 Beiträge |
Oberwellen: AMP bruecken oder nicht? Kermit22 am 26.05.2004 – Letzte Antwort am 27.05.2004 – 8 Beiträge |
Neuer Amp eingebaut -> Remote geht nicht mehr ! H!DDER am 22.04.2010 – Letzte Antwort am 24.04.2010 – 4 Beiträge |
ob ich das jetzt richtig verstanden hab... fredi_2k5 am 30.07.2005 – Letzte Antwort am 04.08.2005 – 11 Beiträge |
gm-1000 amp von pioneer datenblatt daywalker990 am 03.08.2004 – Letzte Antwort am 17.11.2005 – 3 Beiträge |
suche datenblatt audiopipe gm8200 Brueckenwaechter am 05.09.2005 – Letzte Antwort am 16.10.2005 – 12 Beiträge |
Amp Einstellung für Frontsystem denisk am 25.01.2009 – Letzte Antwort am 27.01.2009 – 10 Beiträge |
Subwoofer an AMP anschließen Olli.h am 20.04.2005 – Letzte Antwort am 20.04.2005 – 4 Beiträge |
2003
- Autoradio anschließen
- Unterschied 2 Ohm / 4 Ohm?
- Kein ILL und ACC
- Kein ILL und ACC
- Registrierte Mitglieder931.064 ( Heute: 2 )
- Neuestes Mitgliedcrystlerason3
- Gesamtzahl an Themen1.564.624
- Gesamtzahl an Beiträgen21.860.809
